ALL BORE OR STROKER ????
Old Nov 13, 2002 | 06:53 PM
brent eb02's Avatar
brent eb02
Default ALL BORE OR STROKER ????
im thinking about a new set-up
with all the new sleeveing technology all bores can go 400+ cubes
or should i just go with a 383 stroker???
which one is better when it comes to hp/tq???
[Modified by brent eb02, 11:54 PM 11/13/2002]
Old Nov 13, 2002 | 07:36 PM
Redline Motorsports's Avatar
Redline Motorsports
Default Re: ALL BORE OR STROKER ???? (brent eb02)
Brent,
The "all-bores" tend to make more HP vs. a "stroker" motor. The strokers tend to be a "torque" maker.
Of course a mix of them both should get the job done. :lol:
Julio, just got done dynoing a mild 418 that spun 510/498. I hope my 418 being a little more aggressive should be closer to 525/520 :crazy:
What are you getting bored??
Old Nov 13, 2002 | 08:58 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Hey Brent, how about a nice 385 with a T-72 single turbo :yesnod: :yesnod: :seeya
Old Nov 13, 2002 | 10:26 PM
Redline Motorsports
Default Re: ALL BORE OR STROKER ???? (CHRIS NJ C5)
Brent,
How bout ALL MOTOR!!! :lol:
Old Nov 13, 2002 | 11:12 PM
brent eb02's Avatar
brent eb02
Default Re: ALL BORE OR STROKER ???? (9D9LS1)
i really want to stay with the ls6 block
chris i want to see more proven results from the single turbo set-up before i go that route...
sooo many options.......
Old Nov 13, 2002 | 11:15 PM
Bill Reid's Avatar
Bill Reid
... or a 427 ;)
Old Nov 14, 2002 | 01:25 AM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Default Re: ALL BORE OR STROKER ???? (billreid1@***.net)
Do a search and you will find a ton of info that was covered in just the last month. :cheers:
Old Nov 14, 2002 | 03:48 AM
C5_PIG's Avatar
C5_PIG
Default Re: ALL BORE OR STROKER ???? (C5-VERT)
Brent why the sudden interest in different set-up?? Just get the juice dude!!!!!!!!!!!!!!!!! :D :D
Old Nov 14, 2002 | 08:32 AM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: ALL BORE OR STROKER ???? (C5_PIG)
Brent, I know dragracing is a big interest of yours with this car so I would recommend going with an All-Bore... The stock crankshaft is more than capable of handling the RPM and HP/TQ an engine like this will make. The larger bore will help with unshrouding the valves, letting you rev nice and high to keep in your peak power making RPM range, and getting you many more cubes than a 4.0" stroker crank would.
However, if you are in a position to drop another $2000 or so into this engine, I would recommend dropping a 4.0" stroker crank in as well and make it a 422+ci.
Old Nov 14, 2002 | 10:11 AM
Ed@Lingenfelter's Avatar
Ed@Lingenfelter
Default Re: ALL BORE OR STROKER ???? (MattG)
I agree with Matt, if you can swing the extra money, go with a sleeved block, and a stroker crank. You will have the benefit of 427 cubes(HP and Torque) without having to spend $6000.00 on a C5R block.
Ed
To ALL BORE OR STROKER ????
