Help with wheel Offsets
Old Oct 6, 2019 | 10:06 PM
rkol297's Avatar
rkol297
Default Help with wheel Offsets
Hello,
im looking for new wheels and I found the TSW wheels at 18/9.5 for the front and 19/10.5 for the rear.
However, the offset for the fronts is 40mm and the rears is 65mm.
im going to Autocross and need to be within 7mm +/- with or without spacers. Can I make these wheels work if I use spacers?
Old Oct 7, 2019 | 09:43 AM
jjc508520's Avatar
jjc508520
This is the size combo I'd like to go with as well...
Old Oct 8, 2019 | 04:06 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
I am not an expert on this but it looks like the rear rims would be fine, but the fronts won't work because adding a spacer is equivalent to reducing offset. So you cannot get it to be within 7mm of the stock C5 Z06 offset of +54mm by adding a spacer.
To Help with wheel Offsets
