Run Flat Air Pressure
Old Oct 8, 2019 | 04:13 PM
ALLEN007's Avatar
ALLEN007
Default Run Flat Air Pressure
I have Michelin Pilot Sport A/S Plus (zero pressure). They say 51 psi max. I found a thread on here that say on avg. around 30 psi cold would be good. Is that still ok when the tire say 51 max? (just got the car)
Old Oct 8, 2019 | 04:27 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
30 for best comfort !!!!
Old Oct 8, 2019 | 06:02 PM
wrmiles's Avatar
wrmiles
Don't go to 51, It will ride hard and wear out your tires quickly.
Recommended tire pressure should be an the door jamb placard and in the owners manual. I have found with Michelin runflats that it is best to be on the low side of recommended (like 30 psig hot instead of cold), especially the rears, to avoid excessive center wear.
Old Oct 10, 2019 | 09:55 AM
johnson-rod's Avatar
johnson-rod
I had those tires. They are great!
28 to 30psi cold was best.
Old Oct 10, 2019 | 10:56 AM
jackthelad's Avatar
jackthelad
The 51 psi is just the highest pressure Michelin allows for that tire. "Correct" C5 TP (per the owner's manual) is 30 psi. If pressures go above 35 IIRC, and certainly below 25 the TPMS system will throw up warnings.
To Run Flat Air Pressure
