Help with headlamp issue
Any input is appreciated- I searched the froum but couldn't find anything with this problem.
I was hoping other C5 owners ran into this issue and let me know what the fix was.
Since both of your headlamp doors are opening and closing as they should, your headlamp module should be fine. By the same token, considering that your left low beam always turns ON, your Multi-Function Switch (MFS) should be fine as well. As you can see in the schematic below, the MFS provides a single output (tan wire) to feed both headlamps: the left one through Fuse 10 and the right one through Fuse 8.
Get a multimeter, open the hood, open the underhood fusebox and turn ON your headlights. If your right beam doesn't turn ON, check voltage on both testing points on the upper edge of Fuse 8. If both testing points have power, then you will need to check voltage at the input connector of your right HID ballast. If there is power at the ballast, but the right bulb doesn't turn ON, it could be that Ground Point G102 (on top of right frame rail, behind right headlight) needs to be cleaned.
You should check all connections/splices on your right HID installation. It might be an intermittent contact and when you action your headligh doors several times you make it work. It could also be a failing ballast or HID bulb.
