FLP pre-install inspection..........
All parts & instructions in the box.
Coating looks nice and even.
I sure do like the look and the design:D
I do have a concern on the "curfing in" of angled pipe & the jigging job done on the flange alignment(s)......
The AIR tubes could be a PITA to align (Degree angle &/or jig issue), inside the flange is not a smooth transition zone for the tube to flange weld. Not a clean "fairing in" job.
2 of the O2 bunges are not ground flush with the inside dia. of the tubes/header. All 4 should be cleanly faired into the surrounding inside pipe radius.
I was anyway, but the instruction do say to chase the O2 threads to assure ease of installation. I always do this with any new threads before assembly. Get any weld spatter/thread chatter marks/manufacturing crap out or YOU MAY DAMAGE YOUR O2 sensors during installation.
I have seen local guys have O2 issues, come to find out they were damaged while installing into unchased bungs.
On one of the X-pipe flanges on the back, the flange itself is cocked on the tube and has approx 1/8" sticking out from the flat flange face for 15 degrees rotation ....maybe a leak point. I may have grind it flat, I will check during initial fit-up.
I will post all the info once installed.
None of these issues will hurt performance, but it sure can be an install issue.
Pics will be up one day :D
Does anyone know if the Manufacturing tolerances include the coating thickness??
I am a Nuc in a Non-Nuc world..........this may pass with time :lol: :cheers:
I installed FLP's on my 01 coupe this weekend. I noticed some of the same "features" you found. The passenger side AIR was a PITA because of the flange angle. The cat flanges were rough but cleaned up nicely with a flat file. I didn't chase the O2 threads nor did I use antisieze as called for in the service manual. Hopefully the jet hot ceramic on the threads will prevent thread lock if I ever need to remove them. The header flange plates had a slight convex bow but flattened out when torqued. In spite of a few imperfections, I still rate these headers as a great value and have no buyer remorse whatsoever. Here is a link on jet hot coating. It has the thickness spec but I couldn't find the tolerance. Good luck on your install. The performance improvement was great!
http://www.jet-hot.com/engin2.html
Alan :seeya
[Modified by alc2001, 9:04 PM 11/14/2002]
If I wasn't sure of the FLPs, I sure would not have gotten them.
When I buy something, I do my homework!
I just want to make sure FLP gets feedback both pro & con.
I am in Quality Control, and the few small items I see here are easily fixed with attention to detail.
I have sent FLP this info too, I hope to see a responce next week.
They should be able to answer my tolerance question. I know the coating thickness. My question is more geared toward the potential tolerance stack-up.
Here are a couple of pics to show what I am taking about.
Julie asked last night "When are ya guna put them on honey?????", they sure look pretty, and should sound :cool:.... New tires again huh :eek:
I guess after the Turkey goes in, I will be under the lift :D
Click on the pictures to enlarge them.......
[Modified by ALLTHROTTLE&NOBOTTLE, 2:08 PM 11/21/2002]
Funny thing is, most of the issues I had with my set were fixed in "version 2" that they recently released. :lol:
Sure hope to have no major fittament issues.
It is sad that you have to post on the forum for a company to listen to you. I am glad to hear that they have changed the way they are packed but I am a little disapointed they dont listen to the consumer with ideas and suggestions. My fit was pretty good and I didn"t have this new airtube issue. Only problems with mine were getting everything to line up and seal well and the o2 bungs were a little too far back. I love the headers but a little more attention to detail would make them the headers of choice for everyone. :cheers:
Thanks,
Finger-tighten the v-clamps??? :lol: :lol: :lol:
For the o2s, around the header, I pulled away the wire from the tie that keeps it to the body. I kept it out of the way of the header and then i pulled the slack all the way through and got just enough to get it into the rear bung.
All the weld penetrations look fine.
Everything fit/looks just fine :D
Clamp bolts 3 5/8" long
<img src=" http://temp.corvetteforum.net/c5/30s...erwithpipe.jpg " border=0>
<img src=" http://temp.corvetteforum.net/c5/30s...headerassy.jpg " border=0>
