My brother just dropped a supercharger into a new Mustang and ran a 12.50 at 115mph. I have a 2k1 vette with headers, XR-1 exhaust and the intake system. I need to know what else to do in order to beat him before we end up hooking up. Please advise. :confused:
Not a drag racer, but since no one was responding to you post:
I read some numbers the past few days in reference an 01 Z06 running in that range or faster (stock). Do you think you could be a stock '01 Z06? The real question is what type of tires you have. Drag radials will get you 0-60 time down. The goal would be below 2.0 seconds.
That's just what I've heard other guys talking about.
Easy way to win:
Drag radials - nittos should have you in the 1.9 60' = 12.6 to 13.0
or
Nitrous - 50 or 100 shot would put you in the low 12's = 12.0 to 12.5
or
Change Cams - good for 30 rwhp and a mid to low 12 (see sig) My car went 12.7 with a friend driving before the cam. = 12.6 to 12.8
or
gears - a friend has the same setup as you but with 4.10 gears. 12.4's at 114. = 12.4 to 12.7
Those are your options - all are less than 1500 installed and should give you a 12.5 or better run, if you currently run low 13's.
