Read this could be caused by loose connection of wiring that goes thru passenger door
any other thoughts on cause?? What does “servicing” these areas entail??
2000 Corvette, 84k miles
Pull the codes on your DIC and post them
1) Turn on the ignition but don't start the engine. 2) Press the "reset" button to turn off any warning messages 3) Press and hold "options" and 4) While holding "options", press "fuel" four times within a 10-Second period
My problem a couple years ago was the ecbm relay needed resoldering. Done deal and no problems until my battery went bad , Change that 6 yr old thing out and no problems since. Over 30K miles since I did the job.
