Flywheel balance weights
I have read reports on the forum about the necessity of making sure the flywheel is indexed properly to the crankshaft and that the balance weights were moved to the new flywheel. I also have a GM Service Manual and that tells you to move the weights.
I get the car back and notice a vibrations at 2500 rpm and also between 3500-4500 rpm in any gear when the engine is under load. It wasn't horrible but very annoying.
After a few weeks I took the car back to the dealer and he checks it out and ends up scheduling a GM field engineer to look at it. The next week the engineer shows up with instrumentation and balances the engine in the car.
All that was done to fix the situation was to remove the balance weights from the flywheel - so there are now no weights. Didn't need to remove the trans and driveshaft to do this. I didn't speak directly to the engineer but the service manager told me that he was given bad instructions from GM during the clutch install and that they should not have moved the weights to the new flywheel and that the service manual is wrong.
My car is great now.
So I'm really confused as to why what was done to my car is the opposite of what some of you have experienced and what the service manual says.
I'm wondering if GM actually changed their design and balancing process because it was so confusing to the dealers.
Does anybody have more information?
Someone chime in and let me know if I am wrong.
Maybe if the flywheel wasn't properly indexed to the crank, THEN removing the weights might have brought it within tolerances. But that scenario is pretty far fetched in my mind. A case of two wrongs making a right through coincidence.
Glad ya got her fixed.
Mark
