Some Codes
Old Nov 4, 2019 | 10:12 AM
RPGR90s's Avatar
RPGR90s
Default Some Codes
Over the weekend, I pulled and cleaned all of the relays and large fuses in the engine compartment. All of which had extremely discolored male pins.
I drove it around a bit and then last night decided to check the DIC (just playing around with the dash buttons).
And these popped up.
40-BCM:
B2482H, Backup Lamp Relay
B2527H, Horn Relay
BO-RFA:
U1096H, Loss of Comm., IPC
U1064H, Loss of Comm., BCM
U1016H, Loss of Comm., PCM
I'm reasonably sure these are a result of all the relay, fuse removal's but wasn't sure because the ignition was obviously off when I did the cleaning.
Thanks,
Car runs fantastic btw, after getting the Amazon (GM Delco) fuel filter replaced, and now I have the correct fuel pressure.
RPGR90s
Old Nov 4, 2019 | 11:12 AM
STRMLNE's Avatar
STRMLNE
The H indicates that they are history codes. I would just clear all the codes and see which, if any, come back.
