PS Pulley puller/installer?
Old Nov 15, 2002 | 09:56 AM
7LitreC5's Avatar
7LitreC5
Default PS Pulley puller/installer?
I need to pull off my power steering pully and reinstall it. Does anyone know where to get the tools and what the part numbers are? I understand that Snap-On has them but I don't know which ones are the correct tools. The service manual says to use tools J-something but I don't know where to get those either.
Thanks.
Old Nov 15, 2002 | 10:31 AM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Re: PS Pulley puller/installer? (mforbes)
I believe the J-**** #s are for the Kent-Moore GM specialty tool catalog. Call your Dealer? Or call 1-800-GM-tools item#- GM01-319 for catalog. Good Luck! :cheers:
Old Nov 15, 2002 | 01:49 PM
55SUX's Avatar
55SUX
You can call Kent-Moore at 1-800-345-2233
Old Nov 15, 2002 | 09:35 PM
7LitreC5's Avatar
7LitreC5
Thanks for the info. I ended up getting a puller/installer set from one of the local Snap-On dealers.
Old Nov 16, 2002 | 01:16 AM
Bill Reid's Avatar
Bill Reid
If anybody can pull the pulley off of a powersteering pump AND reinstall it with the pump STILL in working condition on a C5 using the tools called out for in the manual... hats off to ya brotha :yesnod:
:cheers:
Old Nov 16, 2002 | 02:07 AM
corvette184's Avatar
corvette184
Default Re: PS Pulley puller/installer? (billreid1@***.net)
:cheers:
they should get ahold of snap on or mac tools it will last forever :yesnod: :yesnod: you get what you pay for :yesnod:
Old Nov 16, 2002 | 04:11 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
So should we use the Snap On ps wheel puller?????
:cheers:
:confused: :cheers:
Old Nov 16, 2002 | 04:23 PM
C5Tuner's Avatar
C5Tuner
Default Re: PS Pulley puller/installer? (binksZ06)
We have pulled several pullies off the power steering pump. Each time using the Kent-Moore (GM specific) puller. And each time we break the hub off the pulley. The Snap-On is the same design and will do the same as the Kent-Moore. Still in search for a better puller. After using the Kent-Moore pulley installer and installing the pump and pulley back on the car, the pumps went bad. So it is easier and less time consuming to buy a new pump and pulley from the dealer.
Old Nov 17, 2002 | 01:57 AM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Re: PS Pulley puller/installer? (C5Tuner)
Thanks! :cheers:
Old Nov 17, 2002 | 08:20 AM
7LitreC5's Avatar
7LitreC5
Well, that's not good news that pulling the pulley kills the pump. I really don't want to have to take this back apart again...
To PS Pulley puller/installer?
