Low tire pressure
Old Nov 12, 2019 | 10:39 AM
Bills01vett's Avatar
Bills01vett
Default Low tire pressure
Anybody have the issue with one of the tire pressure monitors reading low tire pressure when the temps drop? Temps in sw Florida right now are in the 80’s during the afternoon but dropped into the 60’s last night and I got a low tire pressure warning. Cleared it, drove and got my coffee on the way to work and didn’t get it again. I just changed one of my sensors with a ac delco sensor as it was bad, wouldn’t read at all.
Old Nov 12, 2019 | 12:24 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
Tire pressure drops with temperature 1 or 2 lbs per 10 degrees. So if you were borderline on your tire pressures you could get a low pressure warning. You did not post what the actual readings were so it's hard to tell if it's really a defective sensor.
