Oil leak?
Old Nov 16, 2019 | 08:26 AM
colderbythelake's Avatar
colderbythelake
Default Oil leak?
I have a 1999 Corvette coupe with about 37000 miles on it . It has an oil leak that needs to be fixed. I was just wondering if there was an oil leak that was common on an ls1. Thanks for any info!
Old Nov 16, 2019 | 08:53 AM
wscott62893's Avatar
wscott62893
There are a handful of suspect areas for an oil leak. We would need more information to better make a suggestion. Do you know approximately where the leak is coming from?
Old Nov 16, 2019 | 09:08 AM
DDaaryl's Avatar
DDaaryl
Check the oil pressure sending unit in the back of the motor on top
Old Nov 16, 2019 | 01:12 PM
colderbythelake
Thanks!
Old Nov 16, 2019 | 01:30 PM
Chillo32's Avatar
Chillo32
Rear seal/cover, oil pan, front seal/cover, oil sending unit are common.
Old Nov 16, 2019 | 01:35 PM
colderbythelake
Thanks!
Old Nov 16, 2019 | 02:11 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
Valve covers are fairly common on LS engines, too.
Basically... everywhere. haha
Old Nov 16, 2019 | 02:26 PM
bad455ta's Avatar
bad455ta
Oh come on...these cars aren't prone to leaking ...I've had multiple LS cars and none of them have had leaks. However, I have seen where low mile cars will leak from the front cover after being driven for a long period after years of not being driven very much. This is due to hardening of the gaskets. Do a search in the tech forum and you'll find lots of info. Good luck and enjoy your beautiful car.
Old Nov 16, 2019 | 02:32 PM
Stingroo's Avatar
Stingroo
They don't usually leak horribly, but they almost all leak when they sit.
And it could be from anywhere.
Old Nov 16, 2019 | 02:36 PM
Chillo32's Avatar
Chillo32
20 year old gaskets aren’t prone to leaking? Lol.
Old Nov 16, 2019 | 03:20 PM
bad455ta's Avatar
bad455ta
Not to the point where I would consider the LS to be a problematic oil leaker...like I said, I've has multiple LS cars and none of them have had leaks. High and low mileage, stock daily drivers and modded ones too. From 1997 to 2003 models.
Old Nov 16, 2019 | 03:27 PM
Chillo32's Avatar
Chillo32
Well, if you do just a cursory search on this forum, you would see tons and tons of oil leak threads. Difficult to define the word “prone” in your post. Hard to argue against the fact that rear/front seals and oil sender aren’t “prone” aka “common” to leak on these cars. I’d be willing to bet that nearly every c5 owner has one of those leaking or it has leaked in the past. So if that’s the definition of “prone” then yes, ls engines are prone to leaking oil.
Old Nov 16, 2019 | 03:56 PM
Moved to C5 Tech.
Old Nov 17, 2019 | 07:59 AM
awches's Avatar
awches
LOL on not prone to leaking. Of course the prior owners only put about 3000 miles in 3 years they had it. Had a slight leak when I brought it home. Fixed the leak on the HP power steering hose 1st off. Cleaned engine to see where else it was leaking. Hmmmm front, back, valve covers all seeping. Finally after 2.5 years and 35,000 miles, it was getting worst . So to the shop it went. all seals, pulley, gaskets changed and engine cleaned. 300 miles since the job and still have a clean engine that just crossed 144,000 miles.
Old Nov 17, 2019 | 06:33 PM
colderbythelake
Thank you!
Old Oct 29, 2020 | 03:36 PM
grinder11's Avatar
grinder11
They aren't your Grandfathers gaskets!! Most are sealed with high quality seals, and o-rings, or o-ring type material. They are mostly a black rubber (a type of viton?) material bonded to aluminum to prevent over compressing the rubber like material. They aren't the old school gasket materials, cork, etc. If you put an LS engine together, and it leaks, you've done something wrong on the install...
Last edited by grinder11; Oct 29, 2020 at 03:48 PM. Reason: Spell and more info to add
Old Oct 29, 2020 | 04:00 PM
grinder11's Avatar
grinder11
Valve covers are one place I've never had a leak on an LS engine. Maybe the early perimeter valve covers (why GM EVER reverted to perimeter valve covers on the LS1, after finally going to center bolt covers on the traditional SBC, I'll never know) are prone to leaking, but my 3 LS engines (all center bolt) have all been non leakers as far as the valvecovers are concerned. But I've also never had any of them for 15-20 years and/or 100,000 miles, either....
Old Oct 31, 2020 | 03:50 PM
c5arlen's Avatar
c5arlen
Moved to C5 Tech.
NO NO Don't move it! This is an important thing for us to "not miss" continuously!
To Oil leak?
