Manual Heater AC control panel replacement
Old Nov 20, 2019 | 03:03 PM
dscottp's Avatar
dscottp
Default Manual Heater AC control panel replacement
Just an FYI that I didn't see listed. If the front of your manual control panel is scratched up, rather than spend hundreds on the corvette tax, I've found that one version of a 2000 through 2003 Impala/Monte Carlo heater control has the same face plate, or dang close. The ***** are different but the face plate is easy to transfer over once you have it out and the ***** will work if your old ones are trashed. They all have the same shaft diameter. Other components move over as well with a little massaging. I de-soldered and replaced the center potentiometer because the stops in my old one were broken and it would just spin 360. The impala panel won't just plug and play due (at least) to LED lighting versus incandescent. I didn't take the time to investigate further
