White smoke
Old Nov 25, 2019 | 06:22 AM
Roger1963's Avatar
Roger1963
Default White smoke
Hello all
I have white smoke very often when idling and sometimes even after the engine is hot. No coolant leak, no oil leak. Coolant level hasn’t change or diminish in the last 4 months after fluid flush and replacement. Any idea ?
Old Nov 25, 2019 | 10:26 AM
JR-01's Avatar
JR-01
Originally Posted by Roger1963
Hello all
White smoke when hot is usually seeping coolant. How do your exhaust tips look? Does it have an odor?
Old Nov 25, 2019 | 10:37 AM
Roger1963's Avatar
Roger1963
I have done 3500 miles in the last 6 months and the exhaust tips are dirty but I presume it is normal. I have to clean them. No odor. Coolant is at max level for the last 6 months.....no leak apparently. Yesterday I bough a product for coolant leak and one for oil leak for preventive measure. Only drove 15 miles since. I will check next WE if it is still smoking white.....
Old Nov 25, 2019 | 11:08 AM
RXTbone's Avatar
RXTbone
Once the engine is warm - put your hand at the exhaust. If it collects moisture, with a sweet smell - it's coolant. If it's dry - it's probably oil. Oil will be what collects on your exhaust tips.
Old Nov 25, 2019 | 11:11 AM
Roger1963's Avatar
Roger1963
Originally Posted by RXTbone
Once the engine is warm - put your hand at the exhaust - if it collects moisture, with a sweet smell - it's coolant. If it's dry - it's probably oil. Oil will be what collects on your exhaust tips.
thanks will do the test. I always read that oil don’t cause white smoke but rather blue smoke 🙄
Old Nov 25, 2019 | 11:15 AM
RXTbone's Avatar
RXTbone
I run into that too. I've found that at idle, both oil and water can be white. Full throttle - water is white, heavy oil burning will turn bluish/black.
Old Nov 25, 2019 | 07:21 PM
Moved to C5 Tech.
Old Nov 25, 2019 | 08:04 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
White smoke can be also be raw unburned fuel !!...any drivability issues ??..may be stuck open injector !!...watch at 2:10 of video !!
Old Nov 25, 2019 | 10:17 PM
bobgroger's Avatar
bobgroger
Does it smoke after fully warmed up? White smoke when cold is normal condensation.
Old Nov 26, 2019 | 04:09 AM
Roger1963's Avatar
Roger1963
No drivability issue and yes sometimes it smoke after engine is hot. Will do some testing this WE and eventually post a video. Thanks for all the feedbacks
Old Nov 26, 2019 | 08:55 AM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
How well does the engine run? If it runs more or less "normally" then the issue is unlikely to be fuel related. An A/F mixture that is far enough off to create smoke (rich usually = black smoke, not white) would typically create a poor running condition.
White smoke that is created by coolant will have a distinct smell...as will blue smoke created by oil burning. I have seen instances where, by sight, the two (white vs blue) are hard to tell apart. But the odor is the giveaway - they don't smell anything alike.
This time of year, where temps are cooler, the white "smoke" that is actually just the normal water vapor byproduct of combustion and moisture in the exhaust system takes a lot longer to go away (more engine run time).
Old Nov 26, 2019 | 09:04 AM
Roger1963's Avatar
Roger1963
thanks. I think you may be right because the car runs great and no odor. I bought a product against coolant leak and one against oil leak last Sunday and already put that in the engine and coolant reservoir. Hope it won’t hurt.
Old Nov 26, 2019 | 09:24 AM
acroy's Avatar
acroy
check PCV system - can cause white smoke
Old Nov 26, 2019 | 09:33 AM
Roger1963's Avatar
Roger1963
I have installed a catch can few months ago
Old Nov 26, 2019 | 10:02 AM
C5 Diag's Avatar
C5 Diag
"An A/F mixture that is far enough off to create smoke (rich usually = black smoke, not white)"...4XLR8N... "RAW" unburned fuel will exhibit WHITE smoke...WATCH THE VIDEO !!
Old Nov 26, 2019 | 10:21 AM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
You are correct...however, if that much raw, unburned fuel was making it through to the exhaust, you would most certainly have a miss - probably no spark on one or more cylinders...thus, it would not pass the running "normally" test...
Wasn't trying to say you were wrong...sorry if you took it that way.
Old Nov 26, 2019 | 10:27 AM
Roger1963's Avatar
Roger1963
If no coolant and oil leaks do you think it may hurt the engine or some parts in using anti leaks products additives ?
To White smoke
Old Nov 26, 2019 | 10:32 AM
JR-01's Avatar
JR-01
They can gum up the works, but I have used them in other old cars without any problems.
Old Nov 26, 2019 | 10:33 AM
C5 Diag's Avatar
C5 Diag
No worries my friend !!...that is why I had asked if there were any driveability issues...and BTW with a scan tool you might actually see a lean condition...this raw fuel would NOT be seen by the O2 sensor as a rich condition !!...the raw fuel is just taking up space in the combustion chamber !!
Old Nov 26, 2019 | 10:40 AM
acroy's Avatar
acroy
bingo - I'll betcha something is screwy there - is that when the issue started?? put pcv system back to stock and see if the issue goes away
occasional random puffs of white smoke is often something odd in the oiling system letting occasional bursts of oil into the intake...
do not use snake oil products best case they do nothing, worst case they cause long term harm...
