CD Changer Issue
Old Nov 25, 2019 | 07:54 PM
Notover's Avatar
Notover
Default CD Changer Issue
The CD Disc Changer in the trunk will not change from one disc to another on my C5. According to the owners manual you need to press the PROG button on the radio to switch to another disc. I don't have a button with PROG on it. I've tried every button in every combination I can think of with no results. The changer plays the disc just fine but can't figure out how to change to another disc.
Thoughts?
Old Nov 26, 2019 | 12:34 PM
OregonDan's Avatar
OregonDan
Doesn't sound like the factory head unit. Can you post a pic of the head unit?
Old Nov 26, 2019 | 01:59 PM
Chillo32's Avatar
Chillo32
Yeah. My factory head unit doesn’t have a program button.
Old Nov 26, 2019 | 03:26 PM
01pewtervert's Avatar
01pewtervert
I'm pretty sure mine will change the disk by pressing preset button 5. It also says that in my manual.
Old Nov 26, 2019 | 06:29 PM
GCG's Avatar
GCG
Thoughts?
Only headunits with Cassette have a PROG button and it is used indeed to advance to the next CD in the magazine. Headunits with CD do this when the "5" button is pressed.
From the manual:
Operating the Trunk-Mounted CD Changer with the Radio with Cassette
If an error appears on the display, see "CD Messages" later in this section.
1 PREV (Previous)
Press this pushbutton to go to the start of the current track if more than eight seconds have played. If this pushbutton is held or pressed more than once, the player will continue moving backward through the CD.
2 PROG (Program)
Press this pushbutton to select the next CD in the magazine. If a CD cannot be played, its number will be skipped when selecting CDs while using this pushbutton
3 NEXT
Press this pushbutton to go to the next track. If this pushbutton is held or pressed more than once, the player will continue moving forward through the CD.
REV 4 (Reverse)
Press and hold this pushbutton to quickly reverse within a track. Release the pushbutton to play the passage. The elapsed time of the track will appear on the display.
5 (Dolby)
This pushbutton has no function when playing a CD.
FWD 6 (Forward)
Press and hold this pushbutton to quickly advance within a track. Release the pushbutton to play the passage. The elapsed time of the track will appear on the display.
RECALL
Press this button to see what track is currently playing. Press it again within five seconds to see how long the track has been playing.
SEEK
The left arrow works the same as the PREV pushbutton and the right arrow works the same as the NEXT pushbutton.
P.SCAN (Preset Scan)
Press this button to listen to the tracks on all of the CDs in random, rather than sequential, order. RDM will appear on the display. Press this button again to turn off random play.
AM/FM
Press this button to listen to the radio when a cassette tape or a CD is playing. The inactive tape or CD will remain safely inside the radio for future listening.
TAPE AUX (Auxiliary)
Press this button to play a CD when listening to the radio. Press this button to switch between playing a tape in the cassette tape player and playing a CD in the trunk-mounted CD changer, if both are loaded.
Operating the Trunk-Mounted CD Changer with the Radio with CD
1 PREV (Previous)
2 RDM (Random)
Press this pushbutton to play the CDs in random, rather than sequential, order. RDM will appear on the display. Press this pushbutton again to turn off random play.
3 NEXT
REV 4 (Reverse)
Press and hold this pushbutton to quickly reverse within a track. Release this pushbutton to play the passage. The elapsed time of the track will appear on the display.
5
FWD 6 (Forward)
Press and hold this pushbutton to quickly advance within a track. Release this pushbutton to play the passage. The elapsed time of the track will appear on the display.
RECALL
SEEK
AM/FM
Press this button to listen to the radio when a CD is playing. The inactive CD will remain safely inside the radio for future listening.
CD AUX (Auxiliary)
Press this button to play a CD when listening to the radio. Press this button to switch between playing a CD in the CD player and playing a CD in the CD changer, if both are loaded.
Old Nov 26, 2019 | 09:52 PM
Notover's Avatar
Notover
I'll try that, thanks so much!
Old Nov 29, 2019 | 09:43 PM
Notover's Avatar
Notover
Pressing the 5 button changes the disk as suggested. Guess my co-pilot who was reading the manual did not turn the page...lol
Old Nov 30, 2019 | 02:50 PM
GCG's Avatar
GCG
To CD Changer Issue
