2001 C5 start problem
Old Nov 27, 2019 | 11:03 AM
backinthegame01's Avatar
backinthegame01
Default 2001 C5 start problem
I bought my ls1 at 44k miles 3 months ago. it started fine on Sunoco gas. I switched to shell 93 and not long after it acted like the fuel pump check valve was bad or I had a leaky injector (coincidence?). it cranked fine but then conked out right away. I've been playing with the throttle to get it to start and run like when I bought it. I just wanted to ask for a quick cure before I have to do fuel psi leakdown testing. thanks for any help.
Old Nov 27, 2019 | 11:15 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Welcome to the Forum and unfortunately there are no "quick cures"...it takes some diagnosing so you're not changing every part under the sun needlessly...and then hope you get lucky...you always look for any DTC's and if you don't have a scan tool you can use the DIC to pull up any "codes" you may have !!
Old Nov 27, 2019 | 02:58 PM
Fast one's Avatar
Fast one
Try some Techron in the gas first, https://www.chevronlubricants.com/en...d=&product_id=.
To 2001 C5 start problem
