Differential Questions
Old Nov 30, 2019 | 03:42 PM
Cordinvet's Avatar
Cordinvet
Cruising
Default Differential Questions
I have a 03 with 44K on it, bought it about 10 months ago and love it. Since purchasing it is has had a differential noise. I mainly hear it at highway speeds in 5th or 6th.if you back off a bit it tends to go away. Sounds kinda like the gear noise that a truck ring and pinion make. I have changed the lube in it and the oil in the 6 speed for good measure. The noise has not changed. I have a friend that bought a C6 new, and said that his made the same sound when it was new. The noise is not terrible but there, if I have the top down I don't hear it (I know just drive it with the top down). I am just asking is some noise normal?
On a different note I checked the posi differential today and found that with both wheels off and the car in gear I can turn each rear wheel at the axle nut getting a torque reading of about 130 ft lbs on each side. When I mount a rear wheel and put that side on the ground, put the car in gear and check the torque on the unmounted side I get 60 ft lbs on both sides. Are these torque numbers indicating that me differential clutches are ok?
Old Nov 30, 2019 | 05:18 PM
oharal's Avatar
oharal
My fingers are cold and I'm drinking beer outside so I won't describe it all but go read my recent posts I've actually talked about this in at least 2 threads recently. Your diff needs to be replaced. I'm about to change mine a second time. Get a rebuild from RPM or other competent rebuilder.
Old Dec 1, 2019 | 03:07 PM
Cordinvet's Avatar
Cordinvet
Cruising
Thanks for the reply, I did see in another post that when new the torque at each wheel should be about 100 ft lbs. I was wondering if 60 ft lbs on each side could be considered normal with a Corvette that has 44K on it
Old Dec 1, 2019 | 03:13 PM
oharal's Avatar
oharal
I'm not sure what the "end of life" spec is so maybe someone else will know. But I can say that from what RPM told me a diff with 50k on it is "on borrowed time" and like I said I killed one around 60k, ran it another 15k until it was so loud I couldn't hear the radio. I replaced it with one with 80k on it and it lasted 18 months before it got annoying. Since then I have not tracked my car and won't make the mistake of another OEM spec diff once I move into my new house in a couple weeks.
Old Dec 5, 2019 | 01:03 AM
Joshboody's Avatar
Joshboody
Purchased my car with 90k miles and now has 110k... I believe the diff was replaced since it had a brace. Diff has always been noisy, constant whine, under light load... likely heavy load too, but exhaust drowns it out. Clutch break away torque started at 100-ish, then less and been 0 for some time now... can almost spin each wheel. BUT still an LSD on corner exit. No metal when drained that I can see and no slop in the axles and dry seals.
This is primarily a track car with 65+ track days. No plans to rebuild the diff yet as feels fine on track.
just another data point for you.
Old Dec 5, 2019 | 07:10 PM
Cordinvet's Avatar
Cordinvet
Cruising
Thanks for the info, I will probably do the wait and see game. The car will only see about 4K in miles per year.
To Differential Questions
