C5Z + Speed Engineering headers
Old Dec 2, 2019 | 02:01 PM
mk2vr6t's Avatar
mk2vr6t
Default C5Z + Speed Engineering headers
Hi guys,
Been reading lots of reviews on here about these headers. One common question / complaint seems to be integration with stock cat-back. With a Z06 you have a titanium exhaust to add to the complexity. Normally, I would just weld the connection point. Has anyone used these headers with the stock titanium cat-back? If so, how did you deal with connecting the speed engineering x-pipe to the factory cat-back?
Thanks,
Old Dec 3, 2019 | 06:18 AM
INSTIG8R's Avatar
INSTIG8R
The Speed Engineering X-pipe doesn't directly connect to the cat-back. You have to cut the ends off of your existing X-pipe, whether it be stock or aftermarket, right after it bends outwards toward the cat back. The kit comes with reducers to clamp those 'legs' into and the existing cat-back will bolt to the same flanges it was already connected to
Old Dec 3, 2019 | 12:46 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
The mid pipes which need to be cut are not titanium on a Z06
Old Dec 3, 2019 | 01:06 PM
mk2vr6t's Avatar
mk2vr6t
Thanks for the help, this makes perfect sense.
Old Dec 4, 2019 | 02:28 PM
wscott62893's Avatar
wscott62893
When I installed these headers, I initially followed the process explained by INSTIG8R above. I was not satisfied with the results and had continual issues with proper sealing of the joints. Current state, I ended up purchasing a Corsa X-pipe (coupled with my Corsa Xtreme axle-back) and used that to replace the X-pipe section provided by Speed Engineering. As a result, I only had to reduce/couple 2 joints of exhaust piping that were a straight run. With SS 4" wide band clamps, I was easily able to seal those straight joints and overall exhaust alignment is significantly better.
That doesn't necessarily solve your issue, but it does provide a solid connection to the axle-back portion of your exhaust and eliminates the need to seal weird none-straight exhaust joints.
Old Dec 4, 2019 | 08:48 PM
CinciZ06's Avatar
CinciZ06
One thing we had to do on some mustang exhausts back in the day was use this stuff on joints, which would help them seal up a little bit easier.
https://www.summitracing.com/parts/p...QaAoqNEALw_wcB
also, some dudes would get a set of these and tighten up the joints a bit during assembly as well.
https://www.amazon.com/Newsmarts-Exhaust-Expander-Muffler-Spreader/dp/B07LCM3PM7/ref=sr_1_13?keywords=pipe+expander&qid=1575508431&sr=8-13#customerReviews https://www.amazon.com/Newsmarts-Exhaust-Expander-Muffler-Spreader/dp/B07LCM3PM7/ref=sr_1_13?keywords=pipe+expander&qid=1575508431&sr=8-13#customerReviews
I will be using both when I install my Speed Engineering headers and exhaust.
Old Dec 4, 2019 | 09:20 PM
smitty2919's Avatar
smitty2919
Look into TPS RPM headers 1 7/8" and stainless (vendors here), I had AMAZING fitment. NO messing with motor mounts/steering shaft etc. dropped right in.
Old Feb 13, 2021 | 08:56 PM
Suspekt360's Avatar
Suspekt360
I would like raise this thread again with a very specific ask about SE header kit and integration with 2001 C5Z cats.
Question: Can these SE headers be connected to factory cats with fabrication?
My 01 C5Z (pup cats and cats) will have a Corsa extreme cat back installed soon. So this is a Corsa X pipe attached behind primary cats.
-> JBA also makes affordable LTs that include connection pipes. Not sure they still sell them (ie part# 6818S) which includes connection pipes.
I would like to add LTs by connecting headers to factory cats (and removing pup cat section). In the end, really just want to salvage oem cats which I think will really take the edge of the volume of the Corsa Extremes and remove fuel smell.
Open to ideas
Thx
Old Feb 18, 2021 | 09:36 AM
Zac Ritz's Avatar
Zac Ritz
Open to ideas
Thx
I'm very curious about the JBA long tubes as well. Havnt seen many posts about them and they are very affordable and look like theyll fit factory cats
Old Feb 18, 2021 | 07:29 PM
cdw's Avatar
cdw
my long tubes extend into the area where the factory cats. are located. it's like the collectors are a little long which will push the factory cats back too far. i'll have to solve this problem by buying aftermarket cats. would really like to use the factory cats but they will only fit into the area where the frame flares out for them and the extra collector length messes that up.
To C5Z + Speed Engineering headers
