Re: Eradispeed+(2 piece) vs regular (Enhanced) Eradispeed.....weight difference? (indypace78)
I don't know the difference between the two piece verses one piece, but I can tell you what the 2 piece +1 weighs compared to the stock rotors.
The total (4 rotors) Eradispeed 2 piece with the larger rear rotor, weighs "17" lbs more than stock. The obvious reason for the higher weight is that the rears have a spacer block, additional fasteners and a larger cast iron rotor.
I don't recall what the front weight comparison was (same size), I think the Baers were heavier, but not much, even with the aluminum hats and holes. I vaguely remember that the rotors were beefier, offsetting any weight savings
So... If you're looking to save weight, look somewhere else :cheers:
