HUD position fix
https://www.corvetteforum.com/forums...d-display.html
The 3rd picture is blurry and out of focus. It is just showing what the unbroken boss looks like.
The text reads: picture of the opposite side - mounting boss is this plastic pin that fits into the hole on the side of the mirror mount. Nothing broken here, just showing the other side.
On mine, the plastic nib on one side of the mirror was broke so I replaced it with a metal screw. On the other side, I was also missing the small grommet so I luckily had one laying around
The biggest issue I had was lining up the HUD display once it was fixed.
There is a slider (has two copper pieces on each end that moves and stops the electric motor movent), as well as a small arrow on the plastic gear that lines up with the main plastic gear.
Once you line up the arrow, put both sides of the mirror in, and put the spring on, it moves the slider. I had the best luck with manually putting the slider back in the middle position once the spring moved it.
If you don't get this right, you wont have a full swing of motion of the HUD display on the windshield, and/or it will be too far up or down when put back in and the motor can't move it much.
I had to keep plugging it into the cluster, sitting it on the right spot on the dash, and taking it back out a few times to get this right
I removed the HUD again & repositioned the mirror to show 6 gears intead of 5, now I don't even see the projection from the side as before.
With both the approaches above, there is whirring noise from the motor when it reaches the bottom but not the top. Once, it goes all way the up, the motor stops.
The video didn't mention anything about an arrow on the plastic gear. After I stumbled upon your comment, I checked again for quite some time, but couldn't find any arrow. Where exactly is it, would you be able to guide me ? And second difference between your method and VettePros is that you move the slider to the center and they keep it on one side.
