2002 Z06 Head Gaskets
Old Nov 16, 2002 | 07:28 PM
hrdtopv8's Avatar
hrdtopv8
Default 2002 Z06 Head Gaskets
Does anyone have the part #'s for the 2002 Z06 head gaskets? Going to swap heads next month and wanted something a bit stronger for my '00..
Thanks!! :cheers: :chevy
Old Nov 18, 2002 | 10:31 PM
C5Tuner's Avatar
C5Tuner
Default Re: 2002 Z06 Head Gaskets (hrdtopv8)
We have the part numbers at the shop. Give us a call. The gaskets come with all necessary parts to change heads. Like intake gaskets, head bolts, and exhaust gaskets.
Thanks, Chad
Old Nov 18, 2002 | 11:21 PM
xtream1's Avatar
xtream1
From: Stealth So Cal GOCC ...comming to invade your neighborhood soon
Head gaskets only....#12498544 $24.25/pr compressed measurement is 0.060"
Old Nov 18, 2002 | 11:38 PM
Bill Reid's Avatar
Bill Reid
Default Re: 2002 Z06 Head Gaskets (xtream1)
Yes, but you want the whole gasket kit which includes the bolts... as they should never be reused. :) ... as per the GM manual.
:cheers:
Old Nov 19, 2002 | 12:20 AM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
If you plan on swapping heads often, I would get the Cometic gaskets because they can be re-used. Or at least I was told so.
Old Nov 19, 2002 | 12:24 AM
rwj383's Avatar
rwj383
Default Re: 2002 Z06 Head Gaskets (Tuan Le)
yes, Cometics can be reused. that's the nice thing about Multi-Layer Steel!!! Now, if FLP would make an MLS replacement gasket for their headers....
Old Nov 19, 2002 | 01:43 AM
hrdtopv8's Avatar
hrdtopv8
Default Re: 2002 Z06 Head Gaskets (rwj383)
Earlier today I was told to make sure that my new heads won't have a "notch" in them. Apparantly, certain model year(s) had a notch in the heads. I don't know what they are talking about, but it had something to do with coolant leaking if I don't stick with the certain year gaskets. Is this true for all LS1's or just F-Body's? :confused: I appreciate all the help you guys or gals are giving me.. :cheers:
To 2002 Z06 Head Gaskets
