Passenger side (not the driver side) window switch.
Old Dec 16, 2019 | 06:23 AM
CorvettePertilli's Avatar
CorvettePertilli
2nd Gear
Default Passenger side (not the driver side) window switch.
Whenever I press the up button (only on the passenger side) the window will go up and the door will lock. Also when I press the lock button (again, only on the passenger side) the door will lock and the window will go up. My passenger window motor went bad so I replaced it. I don’t know if this issue started before or after I replaced the window actuator motor because I never used the passenger side switches before. I’m assuming it’s a bad switch but looking for any advice before I put the door panel back on
