Replacing Bulb.............................
Old Nov 17, 2002 | 12:20 PM
rayjerman's Avatar
rayjerman
Default Replacing Bulb.............................
I have to replace my left front blinker/running light bulb. How do you get to it and what is the easiest way to replace it. It is a 1998 C5. I already have thebulbs, just can't find easy access. Thanks.
Old Nov 17, 2002 | 04:34 PM
Bandit1's Avatar
Bandit1
Default Re: Replacing Bulb............................. (rayjerman)
Raise your headlamps and remove the black plastic fascia around the headlamp (three screws I think). This will give you access to the headlamp bulbs and if your hands and arms are small enough, the DRL/turn signal bulbs which are just below them. Otherwise, you will have to go through the bottom of the front nose fascia which will involve quite a few more screws and alot more time. There have been a few threads on bulb replacement. Try a search. :yesnod:
