No dash lights
Old Dec 19, 2019 | 12:35 AM
Slooby's Avatar
Slooby
Default No dash lights
Lost dash lights. Everything else as far as lights working fine (headlights, parking lights, running lights, HUD, tail lights, signals and hazards). Saw other posts which indicated it may possibly be the multifunction switch but all those symptoms indicated that in addition to loss of dash lights other lights were effected also. I checked the fuses and could not find a bad one (19-25-6). I also tried to put the twilight option on but that didn’t restore the dash lights. I also checked the dimmer switch position but it was fully turned up. Radio lights do work. Anyone have any suggestions on what I may be missing or has anyone had a similar problem which was fixed by replacing the multi-function switch (stalk)?
Old Dec 19, 2019 | 05:07 PM
gmagahis's Avatar
gmagahis
6th Gear
Maybe something happened with the UV backlight? Although I don't even know what that UV backlight is called, I know it's located on the sides of the cluster gauge. I've been trying to get mine replaced as well as the backlight is starting to dim out; I heard there's an LED replacement to it too. I wonder if anyone knows what the UV bulb's exact name is.
Old Dec 19, 2019 | 06:05 PM
Life’s good C5's Avatar
Life’s good C5
I had a similar issue and the rear lights weren’t working and I opened the passenger side fuse box in the foot well and started reseating fuses and pressing on the relays and mine issue cleared, just saying what worked for me.
Old Dec 19, 2019 | 06:25 PM
Slooby's Avatar
Slooby
I tried that first. I was hoping it was a fuse. I checked them and they are fine
Old Dec 19, 2019 | 11:43 PM
Moved to C5 Tech.
Old Dec 20, 2019 | 09:05 AM
Phanni's Avatar
Phanni
A commonn failure s in the multi function turn signal, light switch on the left side of the steering wheel. The contacts for the dash lights are built I no this 'stem'.
Old Dec 20, 2019 | 12:49 PM
Slooby's Avatar
Slooby
That’s what I’m figuring it may be. The only reason I hesitate is everyone who describes this problem seems to have some other light issues going on, like no tail lights. I guess I’ll bite the bullet and go for the multifunction signal replacement. Thanks everyone for the imput.
Old Dec 21, 2019 | 01:06 AM
BigGun's Avatar
BigGun
The twilight option bypasses the stalk so I would look elsewhere. Check to see if you are getting power to the fuses.
Old Dec 21, 2019 | 01:27 AM
Slooby's Avatar
Slooby
I checked the fuses but I didn’t check to see if they had power going to them. Thanks for the suggestion. I’ll try that and I’ll check the grounds. These are great cars but electrical nightmares.
To No dash lights
