Engine Coolant Temp
Old Dec 20, 2019 | 04:31 PM
ALLEN007's Avatar
ALLEN007
Default Engine Coolant Temp
I've not had my C5 very long and was wondering about the coolant temp. Mine is running in the 180's while moving, in the 190's while stopped at a light. Is that fairly standard?
Old Dec 20, 2019 | 04:42 PM
c4cruiser's Avatar
c4cruiser
Those temps are fine.
Old Dec 20, 2019 | 07:50 PM
STRMLNE's Avatar
STRMLNE
Do a search. Perhaps hundreds of threads on temps. All the way up to 230 is fine.
Old Dec 20, 2019 | 10:55 PM
wrmiles's Avatar
wrmiles
Acutally a little low for a stock thermostat (about 192).
Old Dec 20, 2019 | 11:37 PM
StingrayRebel's Avatar
StingrayRebel
it sounds like the car may have been tuned, they tend to run up into the 230ish range when bone stock
Old Dec 21, 2019 | 09:15 AM
Gordy M's Avatar
Gordy M
For racing, HPDE, autocross, those are good temps as you only look at oil temps in those events, for gas mileage and emissions, the 220-230 temps were the sweet spot in the initial testing and certification process. The LS1 engine is more efficient at the higher temps than the older 327-350 engines. Personally I like to keep my oil temps below 260 on the track and 240 when autocrossing so my fans are set to come on accordingly. When starting the engine, I always wait till the oil temps hit at least 180 before getting above 3000 rpms.
Old Dec 21, 2019 | 10:05 AM
Josephu's Avatar
Josephu
Good, well thought out game plan and post....
Old Dec 21, 2019 | 09:59 PM
1190405's Avatar
1190405
Even on cool days, my temps will creep up fairly fast in heavy traffic....I had my fan activation temps lowered by 10 degrees across the board to help with cooling
To Engine Coolant Temp
