Code help needed ( RFA U-1064 H )
Old Nov 17, 2002 | 08:21 PM
RPO_Z06's Avatar
RPO_Z06
Cruise-In III Veteran
St. Jude Contributor
Default Code help needed ( RFA U-1064 H )
I need help trying to figure out what lost communication, I have no problems that I can tell but I have this code and it won't go away.
Again its RFA code U-1064 H :smash:
Thanks.. :cheers:
Old Nov 18, 2002 | 12:52 AM
ScreaminDemon's Avatar
ScreaminDemon
Default Re: Code help needed (RPO_Z06)
RFA-remote function actuation, u-1064- loss of communications with the DCM and a h-history code. Sounds like a bad sensor module somewhere but I would first check your positive battery terminal for leakage. Our Delco batteries are notorious for leaking and ruinning the wires and pcm that is below it. Sorry I can't help more.
David
Old Nov 18, 2002 | 09:18 PM
RPO_Z06's Avatar
RPO_Z06
Default Re: Code help needed (ScreaminDemon)
I know it's not a battery leaking, I put an Optima in my car right after I got it.
Thanks for the info though. :cheers:
Old Nov 18, 2002 | 11:11 PM
alc2001's Avatar
alc2001
RPO - I'll send you the service manual page on this DTC via email. Maybe it will help.
Alan :seeya
Old Nov 18, 2002 | 11:28 PM
RPO_Z06's Avatar
RPO_Z06
Default Re: Code help needed (alc2001)
Alan :seeya
Thanks man ! :cool: :cheers:
To Code help needed ( RFA U-1064 H )
