Axxess XSVI-2004 NO RAP
The Axxess adapter interfaces with the Serial Data Bus, like the OEM Headunit, and no additional Accessory Switched Power connection is required.
The Axxess receives the appropriate command via Serial Data Bus when the ignition switch is moved to Accessory or Run, and provides the aftermarket headunit with the equivalent of an Accessory Switched Power wire through the Red wire.
This ability to interface with the Serial Data Bus is also how it can preserve the RAP feature, by keeping the red wire energized for a certain time after the ignition switch is turned OFF or until a door is opened, whichever happens first.
Thanks! hopefully either no issues, or I just accept it. Because Axxess just said it is an issue with our cars and the locks....
UPDATE..... RAP ..... Well, when I turn the key off, it powers off, then reboots.... and stays on.... So, Axxess just blames the car. I saw a fix to this with a capacitor type setup, maybe I will do that.
Yes, going OFF-Rebooting-RAP is a known issue and the fix with the capacitor was my idea
. Click here for more details
AH YES GCG! the genius behind the fix! I ordered some on Amazon today! THANK YOU
GCG was in fact the creator of the fix but I think he should start linking to the proper thread where the fix was identified and tested to actually work...
https://www.corvetteforum.com/forums...2004-help.html
Having to click a link to another message is a hurdle, let alone having to read a whole thread to find what they're looking for. That's why in another thread from August '19 I summarized everything in a single post, to which I linked to in this one
the topic as a whole should be made a sticky since as time goes on more and more people will be converting their ancient stereo’s to something more modern and need this info.
I vote my thread be stickied.
It works.... maybe too good.
Now, when I get in it does NOT shut off when I go from key in to crank.... it also does not shut off when I turn the car off...…
HOWEVER..... after I shut the car off, disconnect the phone, leave the car, set the alarm... the radio never turned off... I waited 30 minutes and just powered it off manually …. I am assuming all that 30+ minutes is just the caps powering the radio... but WOW... LONG TIME. I don't see how anything else could be wrong
I mean that it has no sound by choice..... I if you stay only playing for 4 minutes.... I guess 30 minutes without playing might be correct....
I connect with my phone for music.... so when I unplug my phone.... no music, just display.
...after I shut the car off, disconnect the phone, leave the car, set the alarm... the radio never turned off... I waited 30 minutes and just powered it off manually …. I am assuming all that 30+ minutes is just the caps powering the radio...
You can easily test all this by selecting a radio station and setting a normal volume before shutting the car off. Let us know how it goes.
Just out of curiosity, how many farads is the capacitor bank you bought? An extremely large capacitor coupled with a silent headunit could also be at play here.
I'm happy with it... much better then booting up twice when I start the car
Now I have another issue... today I dropped the car off to get washed, when they finished the radio was off and would not come back on...…… now I get to tear everything apart again and see what coincidently failed.... UGH!!!!!!!!!!!!!!!!
My being the dummy that I was did not understand that the R.A.P. meant I did not need to connect the accessory wire to the "magic yellow wire", so I had wired to that too. Because of that my car just wouldn't start whenever I tried to start it. Snipped that and it works like a charm. The only weird thing I have is that the radio turns on as soon as I insert the key. Not turn it to ACC or Run, but as soon as the key is inserted into the car. Thought that was kind of weird, but it shuts right off when I open the door... or if the door was already open as soon as I remove the key.
Definitely some weird little electrical gremlins in these cars. I've been doing stere stuff for 23 years now and this was definitely a first for me.
Getting the wiring harness all put together.
Getting the backup camera wired in and looking for a ground for the sub amp.
Backup camera all finished
Custom 8" sub box I build to fit right down in the back tub. Will be adding an 8" Kicker Comp-R and a Toro MR3 micro mono block amp.
The real nightmare... wires everywhere!
Deck in and complete. I switched out the cigarette lights in the console to two USB ports as well for doing CarPlay/Android Auto
