2004 Corvette Upgrade Ring and Pinion Vs Complete Rear Diff
I’m considering upgrading the gearing to 3.73. Could I just have the ring and pinion replaced or would I need to have a completely new rear differential installed?
Any major disadvantages of doing ring and pinion instead of a whole new rear diff?
I will also be having a Yank SS3200 installed while the gear work is being done as I hear it’s not much extra work.
I have a 03 convertible automatic with 3.42 gears from a Z06 and i bought a whole diff. You are better buying a whole diff and get it checked or rebuild. Depending of what your future plans 3.42 is more than enough. I have an A&A supercharger with meth injection and im just spinning tires all day. I wished i did a 3.15 instead...Na setup 3.42 is more than enough...
Circle D 2800-3000 stall is more than enough too not unless you are building a drag car. I'm using a 2800 stall.......
