Battery drain, yay.
Old Jan 6, 2020 | 09:23 AM
66dts-v's Avatar
66dts-v
Default Battery drain, yay.
I had my passenger door open and heard an awful buzzing coming from the footwell. Relay 42 was going crazy. I pulled it out, put it back in and it seemed ok. A few hours later I was going to drive it but when I went to move my seat, it didn't. I put my volt meter across the battery and got 4V.
Put it on the charger, got it to 100%, left it overnight and I was at 3.2V this morning. So I will get a new relay, I will also replace the security relay because I haven't done that yet.
Anything else, other than the painful process of trying to track it down? Thanks.
Old Jan 6, 2020 | 01:06 PM
mmartinez's Avatar
mmartinez
Always start with having your battery charged and load tested to ensure its not the battery. I see you mentioned using a voltmeter, connecting it in series with the negative battery cable and battery terminal and selecting 10 amp scale and meter lead terminal on meter to measure current draw. Positive battery cable connects to engine compartment fuse center and passenger side fuse box, lift supply cable to passenger side fuse box to help determine which fuse center has the excessive current draw, and lastly sleep mode current is about 25 milliamps on our cars.
Old Jan 6, 2020 | 01:13 PM
STRMLNE's Avatar
STRMLNE
Couldn’t it just be a bad cell in your battery?
Old Jan 7, 2020 | 10:04 AM
66dts-v's Avatar
66dts-v
Not for it to drop that fast. I mean, maybe, but to go from 12.8 to 3V in 12 hours seems like more than a bad cell.
I will grab a new one anyway since this one is about 6 months old and Napa loves me.
Old Jan 9, 2020 | 04:46 PM
66dts-v's Avatar
66dts-v
Napa tested the battery and it was good. The relay was $22 and seems to have cured it. It was charged last night, took off the charger and showed charged this morning. So far so good.
Old Jan 9, 2020 | 04:47 PM
STRMLNE's Avatar
STRMLNE
Do you charged the battery overnight?
Old Jan 9, 2020 | 04:53 PM
66dts-v's Avatar
66dts-v
I put it on the charger when I got home from Napa at about 4. Was showing charged when I went to bed, so I took it off. First thing this morning I hooked it back up and still showed 100%, so I drove her to work.
Went to lunch just fine, too. As long as she gets me home, I'm happy.
Old Jan 10, 2020 | 05:35 PM
66dts-v's Avatar
66dts-v
Or not, she was dead this morning. I will be pulling fuses this weekend, oh fun.
Old Jan 10, 2020 | 05:37 PM
STRMLNE's Avatar
STRMLNE
I would still probably buy a new battery. (Unless your car has had electrical problems in the past) battery testers from napa and auto zone aren’t too sophisticated.
Old Jan 11, 2020 | 04:23 AM
oelarse's Avatar
oelarse
This is a good and quick way to locate parasitic current on cars .
Using this way instead of pulling fuses it is easier to avoid to wake up the BCM through the trouble shooting
Measure the mV over each fuse and compare to values in fuse charts linked to in the video description .
The correct parasitic current draw can be measured after the BCM has gone to sleep (15 min).
https://www.corvetteforum.com/forums...lp-please.html
Old Jan 11, 2020 | 05:06 PM
heggsc5's Avatar
heggsc5
Mine does the same thing when my battery is low enough to die soon. Fully charged, it's fine. How old is your battery? If it's older than a few years, it's probably suspect for not holding a charge. Any time I've had an odd electrical issue on any of my cars, it's always been the battery. Even if it "should" be fine.
Old Jan 14, 2020 | 09:57 AM
66dts-v's Avatar
66dts-v
It seems I might just be an idiot.
When I opened the door and the light was out and my seat didn't move, I assumed it was again dead. So I drove my truck. After work I put it on the charger and the charger said it was near full.
The negative terminal wasn't fully seated and wasn't making a good connection. So I tightened it and everything seems fine. There is call for snow the next few days, so I will check my voltage daily until then.
The battery is maybe 6 months old. I have never had a battery last more than a year since I have had this car (6 years).
But the relay seemed to have fixed the original issue. :
Old Jan 14, 2020 | 10:33 AM
mmartinez's Avatar
mmartinez
I don't know how it happens, or what causes the battery terminals to come loose, my battery is held down and doesn't move, but every so often I have some weird problems that are corrected by tightening the battery terminals.
Old Jan 14, 2020 | 11:05 AM
66dts-v's Avatar
66dts-v
I have stripped more than one of those bolts, too. Pain to replace, so I don't overtighten. It felt right because the plastic lip on the cable wasn't flush with the battery.
Hope for the best.
Old Jan 14, 2020 | 10:32 PM
jim993's Avatar
jim993
FSM says 11 foot pounds for side terminals. You can't actually get a torque wrench in there, so good and tight.
To Battery drain, yay.
