2004 C5 corvette PCM pinouts
Old Jan 6, 2020 | 10:13 PM
lsrteg's Avatar
lsrteg
Default 2004 C5 corvette PCM pinouts
Hi Guys,
Can anyone share a 2004 C5 corvette P59 PCM pinouts please...Im doing an upgrade from a P01 411 PCM to a P59 corvette PCM. Thank you....
Old Jan 7, 2020 | 12:35 AM
NSFW's Avatar
NSFW
According to this thread...https://www.corvetteforum.com/forums...onversion.html
...all you need to do is move one wire from pin 52 (on the P01) to pin 75 (on the P59).
You will need to disable some fault codes related to O2 sensors. Or with some extra work you can run your O2 sensor grounds through the new PCM, and it will monitor their current consumption, but it's not clear that's worth the trouble.
And either way you'll need to get the PCM and BCM re-acquainted with each other, there's a post here that covers that:
https://www.corvetteforum.com/forums...m-tcs-etc.html
Old Jan 7, 2020 | 01:39 AM
Vette97sc's Avatar
Vette97sc
Here is 2004 Corvette P59 pinout. I add also 2002 if you want compare.
https://1drv.ms/u/s!AiTI9VLrQU6hgXLL...frxst?e=O5RTRr
Old Jan 7, 2020 | 09:11 AM
lsrteg's Avatar
lsrteg
Thank you. I will check it out.
Old Jan 7, 2020 | 09:32 AM
lsrteg's Avatar
lsrteg
Thank you very much.
To 2004 C5 corvette PCM pinouts
