Radio does not shut off
Old Jan 10, 2020 | 07:04 AM
aahoover's Avatar
aahoover
4th Gear
Default Radio does not shut off
Recent 2004 C5 issue where you shut off car, radio is still on, you open the driver door and the radio is supposed to shut off. In my case, not always. To solve the issue, I reach over and open the passenger door just slightly and sure enough, the radio immediately shuts off. Obviously something in driver door that is acting up..
Any ideas? Others suggest removing and reinstalling the fuse under the passenger footrest area but who wants to do that every time I want to get out of my car?
Old Jan 10, 2020 | 09:46 AM
MadMax96's Avatar
MadMax96
Sounds like a faulty/sticking switch on that door - I'm guessing the interior lights don't go on when that door opens either...?
Old Jan 10, 2020 | 10:14 AM
pcfred's Avatar
pcfred
St. Jude Donor '05
When you close the driver door and press the unlock or lock button on the Fob does the radio go off? If so, check the wiring in the door. Do a Forum search, there are a few threads on fixing door wiring/connections.
Old Jan 10, 2020 | 10:49 AM
GCG's Avatar
GCG
I would begin here
Old Jan 10, 2020 | 12:43 PM
aahoover's Avatar
aahoover
4th Gear
Thank you for the suggestions. I did not pay much attention to if the interior lights go on or not. Nor did I try the lock/unlock button but will try those. I just went out to the vehicle, opened the driver door and the light on the rear view mirrod does go on. I try to see where the electrical switch is in the door but did not readily see it. Thinking of the old style in my C3.
I will try to look into this on the weekend, thank you all!
Old Jan 20, 2020 | 10:30 AM
aahoover's Avatar
aahoover
4th Gear
Radio does not go off when I press the unlock or lock button on the FOB.
Old Jan 20, 2020 | 10:31 AM
aahoover's Avatar
aahoover
4th Gear
Originally Posted by GCG
I would begin here
Can someone send me a photo pointing to where the electrical switch is in the door? I do not see it. Thank you.
Old Jan 20, 2020 | 04:00 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
We have become a slave to technology. I always
just turn the radio ****.....off.
Good luck
Old Jan 20, 2020 | 11:13 PM
Rick369's Avatar
Rick369
Good luck
So do I.
Old Jan 20, 2020 | 11:29 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Originally Posted by Rick369
So do I.
Same here...
Old Jan 21, 2020 | 02:14 PM
Moved to C5 Tech.
To Radio does not shut off
