Starting Issue opinion
Old Jan 10, 2020 | 09:48 AM
ALLEN007's Avatar
ALLEN007
Default Starting Issue opinion
About a month ago I noticed when starting (after it sat a few days) the first turn or two would sound like a slight drag (slow turn over) then start right up. The last couple times when I turned the key it clicked the first time. Turn the key off then it cranked right up the rest of the day with no problem. Does this sound like the battery or starter?
Old Jan 10, 2020 | 09:54 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
If I were you being that the car sat for a few days with starting issues I would load test your battery, check for a parasitic draw, and then remove, clean, and reinstall battery connections at BOTH ends and retest !!
Old Jan 10, 2020 | 11:54 AM
STRMLNE's Avatar
STRMLNE
Def battery issue. I would just replace it
Old Jan 11, 2020 | 10:47 AM
mmartinez's Avatar
mmartinez
Make sure your battery is good have it charged and load tested, before going out and just buying a new battery. I have had the same experience with my 97 coupe lately, it lost it's spot in my one car garage to a 37 Plymouth 2dr sedan I bought recently. With colder winter temps and not using my car for a few days, it does the slow cranking, I have measured current draw at 20 mamps. So fire up that car every few days or keep a battery tender on it, especially during winter months.
Old Jan 11, 2020 | 10:50 AM
mmartinez's Avatar
mmartinez
Just noticed your from Florida, don't have to deal with colder temps lol.
Old Jan 11, 2020 | 11:48 AM
CinciZ06's Avatar
CinciZ06
Check form tightness at all your cable connections at the battery and starter, fuse box, and grounds. If those are they tight and there is no corrosion, then get the battery tested. Will be a simple fix no doubt. A bunch of people find their started connections are loosening up over time. And of course batteries are consumed as snacks on these cars.
Old Jan 11, 2020 | 08:46 PM
VetteDreamin08's Avatar
VetteDreamin08
I would do more than load test your battery. I would perform a starter draw test and do a voltage drop over the cables. The draw test and load test you will need access to some specialized tools, but it will narrow down if it's a battery issue, a starter issue, or both/neither. A voltage drop over the cables is easy. With your multimeter From set to DC volts, place each lead at your B+ terminal and your positive lug in your starter. If you see more than 0.4 Volts, you may have an issue in the cable. You can do the same test for your ground cable to frame.
To Starting Issue opinion
