Bi-Xenon ACA headlights Issues
@TheRadioFlyer can you help out with this?
XtremeVision LED Anti Flicker Capacitors - Error Code Canceller Capacitor (1 Pair) - 9006/9005 / 9012 / H10
As to the problem listed: From my research, the headlight doors open and close when triggered by a the high current draw of the halogen bulbs. HID ballasts have a High startup current, but then stabilize current draw at a lower current. Cheaper ballasts that claim to be 55w will not actually have a 55w stable current draw. We go to tremendous lengths to ensure that our ballasts do have this high stable draw both for this purpose and to ensure that the proper amount of light output is generated. In my research, the headlight doors require a minimum of 3.9 amps to retract. The current generation of ballasts have a stable draw of 4.6 amps at 13.5v. (This draw has only been tested on a bench power converter and not on a battery) but should be more than enough to trigger the headlights to lower.
There are several possible issues at hand here:
1) The headlight control module (which controls headlight doors) has failed or is failing
2) The HID ballast (although firing) is not drawing the appropriate power
3) There is a unique issue as yet undiscovered.
We have sold well over 200 of these kits and all ballasts used have been upwards of the minimum 3.9A stable draw. If the issue were with the ballast inherently, I would expect all customer to be reporting the same issue. I will need to know more information from each individual customer to diagnose the issue and take appropriate action. If you are having the "fail to retract" issue, PLEASE send a photo of the ballast you have to president@sharplightinnovations.com so we can gather more information.
I can be reached at president@sharplightinnovations.com
But that is not the relevant part...
If I recall there were 2 harnesses that came with the lights one for each side that allowed the low beam to stay on with the high beam.
The relay harness that came with the lights had a built in resistor that is enough load to trigger the headlight to close when BOTH of the harness were connected.
I experimented with this trying to use only one harness (to try reduce all the wires floating around) - which does not work BTW as the headlights flicker w the 50 W HID ballasts I am using.
It needs both harnesses to work apparently.
I found with one harness or if you unplug the low beam on one side the headlights only retract w the high beam technique.
So apparently the harnesses supply just enough resistance to close lights if it is 2 harnessed on the circuit.
Did you install 2 harnesses or one?
This is the kit I bought:
Honestly, I liked the headlights staying up and using high beam to close. My thought is reducing wear and tear from reduced opening and closing these fragile, plastic gear driven, bouncy lights as much as possible.
But that is just my opinion.
