Cannot get clutch line connected
Old Jan 13, 2020 | 06:44 PM
Silverwolf_pup's Avatar
Silverwolf_pup
Default Cannot get clutch line connected
I cannot get the clutch line connected to slave, I am trying to give it all I have and nothing, what do I need to do please help.
Old Jan 13, 2020 | 07:43 PM
Moto One's Avatar
Moto One
Check how you are routing the line to the quick connect. Also make sure the the lower line exiting the bell housing is pointed forward.
Mark.
Old Jan 13, 2020 | 08:30 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
This tool will have it together in a single squeeze. They are made by various tool makers.
You can do it by hand but good luck.
Old Jan 13, 2020 | 11:38 PM
Toys4Life C5's Avatar
Toys4Life C5
St. Jude Donor '21
Hmmm, I think something must be wrong. I have done it twice, most recently back in spring of 2019 on my C5 and I do not remember there being any issues connecting the line from the clutch master to the slave with just my hands. Was it particularly hard to disconnect from the old slave cylinder? Are can you inspect if closely to make sure it is 100% clean on both parts. New or existing master cylinder?
Old Jan 14, 2020 | 12:20 AM
Moved to C5 Tech.
Old Jan 14, 2020 | 05:49 AM
Silverwolf_pup
Its a brand new oem master cylinder, it just doesn’t want to lock in place, very frustrating.
Old Jan 14, 2020 | 05:51 AM
Silverwolf_pup
Thanks.
Old Jan 14, 2020 | 07:11 AM
CinciZ06's Avatar
CinciZ06
This is maybe a dumb question but do you have the lid off the clutch reservoir so the fluid can flow into it with no resistance as you push the two hoses together?
Old Jan 14, 2020 | 08:11 AM
feeder82's Avatar
feeder82
I had a hard time until I opened the bleeder.
Old Jan 14, 2020 | 09:11 AM
wcsinx's Avatar
wcsinx
The o-ring can bind up if it's dry. Try coating both the male and female fittings with clean brake fluid first, and I'll bet they'll click home easily.
Old Jan 14, 2020 | 12:14 PM
mykream's Avatar
mykream
Bleed the pressure off first.. If there is pressure behind any QC style connector, it will make it very difficult to engage
Old Jan 26, 2020 | 05:12 PM
Silverwolf_pup
I got the lines connected, but I want to know if I got them connected right, the clutch is engaging like it should, there is some play with the connection but won’t pull apart, is it safe to say that it will be fine? Thanks
Old Jan 26, 2020 | 06:50 PM
CinciZ06's Avatar
CinciZ06
If you are saying you can push them together just a bit more and they spring back to the stopping point that is totally normal.
Old Jan 26, 2020 | 10:24 PM
Silverwolf_pup
Why is that, and thanks
Old Jan 27, 2020 | 06:33 AM
CinciZ06's Avatar
CinciZ06
It's the design of the retention mechanism in the hydraulic push fitting. Inside it is essentially spring loaded which keeps it positively engaged against the stop / teeth. I have a slave laying in the garage I can photo that would probably show what I am trying to explain a little better.
Old Jan 29, 2020 | 10:14 AM
Silverwolf_pup
Thank you for summoning all this up for me, I just wanted to make sure that it was ok. Thanks bud 👍🏻
Old Mar 31, 2024 | 08:18 AM
TPacifica's Avatar
TPacifica
Dear Toy 4 life:
I did clean the connection with brake cleaner fluid. The original popped out pretty easily. I don't think and hope I did not damage it.
Todd
To Cannot get clutch line connected
Old Mar 31, 2024 | 08:20 AM
TPacifica's Avatar
TPacifica
Tried that. Didn't help any for me.
Todd
Old Apr 3, 2024 | 01:53 PM
johnson-rod's Avatar
johnson-rod
WD-40 in the QD fitting did it for me. Same with getting the fuel lines off and on the filter and manifold. Those plastic connectors are a biotch to use when dry. One shot and they behave.
Old Apr 4, 2024 | 10:11 AM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
https://ls1tech.com/forums/manual-tr...nto-slave.html
