Air Cond question
Old Jan 14, 2020 | 06:28 AM
ALLEN007's Avatar
ALLEN007
Default Air Cond question
Just recently the AC blows colder on the passenger side more than the drivers side. Any ideas?
Old Jan 14, 2020 | 08:45 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
You may need to pull fuse #27 (HVAV CON) which is "hot at all times" and is located in the passengers footwell for a few minutes and reinstall...see if that works !!...also see if you have any DTC's (HVAC Actuators) stored...access them trough the DIC if you don't have a scan tool !!
p.s. You may also be low on Freon !!
Old Jan 14, 2020 | 02:06 PM
BigGun's Avatar
BigGun
You should certainly check for codes but on a C5 that is often the first symptom of a low charge. If there are no codes that would be the next thing I would check.
If you use a scanner to check it will need to be a good one. Most of the lower cost handhelds will not pick up C5 hvac codes. Use the DIC, you don't have hook any thng up and it is right in front of you.
Old Jan 14, 2020 | 09:58 PM
GUSTO14's Avatar
GUSTO14
Default Obtaining Vehicle Codes from the C5 DIC
Allen, on the outside chance you haven't ever pulled the codes before, here's how it's done...
and one other useful site...
http://www.c5forum.com/ayc/dtcdic.php
Good luck... GUSTO
Old Jan 15, 2020 | 02:55 AM
STRMLNE's Avatar
STRMLNE
More often than not, that is a symptom of low refrigerant
Old Jan 16, 2020 | 08:42 AM
ALLEN007's Avatar
ALLEN007
https://www.youtube.com/watch?time_c...&v=SviRjIsy9G4
Good luck... GUSTO
Thanks. Before I purchased this C5 a few months ago I did check for codes. You Tube is great!
Old Jan 16, 2020 | 10:50 PM
Rick369's Avatar
Rick369
Do you have the dual zone climate control option? If you do, check where the passenger climate control **** Is set. If it is set directly between hot (red) and cold (blue), the temperature should be the same as the drivers side. If the passenger climate control **** is turned all the way to cold, the passenger side will be colder than the drivers side.
To Air Cond question
