Shift effort on '99 FRC...
Old Nov 18, 2002 | 03:24 PM
Trey395's Avatar
Trey395
Default Shift effort on '99 FRC...
I drove my 2002 Z28 the other day and noticed that shifting in that car is a ton easier compared to my '99 vette. Is this just an inherent difference between the cars?
If I go to an aftermarket shifter like the Hurst on the vette will it make things any easier? Thanks in advance!
Old Nov 18, 2002 | 03:40 PM
VetteDrmr's Avatar
VetteDrmr
Default Re: Shift effort on '99 FRC... (Trey395)
Going to an aftermarket shifter won't ease your shift efforts, it'll probably increase them. I've got a '94 Z-28 with the T-56 tranny and a Ripper shifter, and my '00 FRC shift effort is about the same, but I don't like the angular rotations that I go through in the C5. OTOH, during the heat of battle at the local autocross, I don't even notice any problems, I just run through the gears. :D
I've driven a friend's '99 Trans Am, and I thought the shifter in that was sloppy loose, much worse than my Z-28 when it had the stock shifter.
I think the reason the effort on the C5 is higher is because the shifter is remote from the tranny, whereas the F-body's shifter is directly mounted on the tranny.
Hope this helps,
Mike
Old Nov 18, 2002 | 07:45 PM
Trey395's Avatar
Trey395
Default Re: Shift effort on '99 FRC... (VetteDrmr)
Thanks Mike, it's not what I wanted to hear, but I appreciate the input...
To Shift effort on '99 FRC...
