My '98 refused to start. The battery was quite new (a few months old) and under warranty so I took it in to be tested. It was bad. They replaced it and all’s well.
[ I’m a driver with no mechanical skills so if this is an ignorant question I apologize. ]
I'm being told that there could be something wrong with the car that is causing a new battery to fail. If that is so, will running codes tell me what that would be? Thank you all.
If the car sits without a battery tender, is the battery draining? If so, how fast? It can be just normal drain that keeps the electronics alive - that's why they need tenders when they sit a lot. If it drains pretty fast, then the check is not that hard to do - sometimes seat switches get stuck or something else that would drain it.
Yes the car does sit a lot. I don’t drive it often, sometimes it sits outside a couple weeks at a time or more. Will this cause a battery to "go bad"? Can a battery tender be used if the car sits outside? How is it hooked up on my '98?
If the car is going to sit unused for a couple of weeks just take the battery out and bring it inside and put it on the battery tender.
May take 15 or 20 minutes but it will keep the battery fresh and in good shape.
You could disconnect the negative battery cable. This way there would be no draw on the battery. A few years ago I stored my Corvette for the winter months (4 1/2 months) and there was no electrical outlet to plug in a battery maintainer. I disconnected the negative battery cable. When I took it out of storage it started right up.
I’m a disabled older lady so that wouldn’t work for me. I’m getting to the point in my life where I'm beginning to feel it might be time to sell my beautiful car and just go with Uber.
Since no one has replied that my car could be causing the battery to go bad (other than sitting idle) can I assume that is not a concern? Thanks for all your replies so far.
This might be a possibility for me. A pia every time I need to drive, but at least I would know it will start. Thank you.
It's always best to start your car and let it warm up to normal operating tempateure at least once a week, if not you can purchase a battery tender and an adapter cable that plugs into the cars cigarette lighter if the car is going to sit for long periods of time. And to answer your question about your car causing the battery to fail, yes it's possible if the car has excessive current drain when it is parked, you would have to take it to a shop and have them check for that condition.
Thank you so much for that information. And what would cause excessive current drain?
Excessive current drain can be caused by a number of things, stuck switch on power seat, or bad seat module, headlight module, Bose speaker amplifier, the BCM module, and the alternator as well. A good shop should be able to determine if your car has excessive current drain and if so what is causing it.
I would guess that since they replaced the battery that it was actually a bad battery..... and less likely caused by your car..... just try your new battery, and if no issues, ....... life is good :-)
(and have a pair of jumper cables in your car for now)
Joel
not necessarily. I’ve had pep boys hand me brand new batteries many times just because they didn’t want to have it sit in a charger and have me come back (and all the cells were fine).
