Beamtech Hi beam interference fit
Old Jan 19, 2020 | 01:20 PM
LstHura's Avatar
LstHura
Default Beamtech Hi beam interference fit
Has anyone had success installing the high beam from Beamtech into the stock C5 headlight? I attempted to this in my 2004 but the actuator arm to lift and lower the headlight, hits the heatsink on the bulb.
Old Jan 19, 2020 | 04:57 PM
GCG's Avatar
GCG
Can you post some pictures?
Old Jan 19, 2020 | 06:08 PM
LstHura's Avatar
LstHura
No, sorry. I already put the stock lights back in. I should have clarified, I have are the S1 series which have a rectangular shaped heat sink.
Old Jan 19, 2020 | 10:57 PM
STRMLNE's Avatar
STRMLNE
I thought the BeamTech high and low beams for no problem in c5’s
Old Jan 20, 2020 | 05:10 AM
AUandAG's Avatar
AUandAG
I don't know if this will help you but I have the Beamtech led's in the high beams of the ACA headlights. With the heat sinks vertical they barely clear the actuator arms. Were your heat sinks installed vertically? I can't remember if I had to loosen a screw to orient the heat sinks vertical.
Old Jan 20, 2020 | 09:18 AM
LstHura's Avatar
LstHura
When installed the lower end of the heatsink is aimed at about 8:00. There is a set screw that I took out and turned the lockring but there is only 1 hole for the screw to fit into. I contacted Beamtech and they asked if I had any pictures so they can check. I may have to take the headlight apart to reinstall the bulb for them. If I do, I will post a picture here as well.
Old Jan 20, 2020 | 09:55 AM
LstHura's Avatar
LstHura
STRMLNE, that is what I thought as well. I'm hoping someone has installed these and can maybe tell me what I did wrong.
Old Jan 20, 2020 | 12:30 PM
LstHura's Avatar
LstHura
This shows the interference between the actuator and the back of the heatsink. The only way I could get the bulb into the socket was to dissasemble the actuator then insert the bulb. After doing that, I could not re-assemble the actuator due to the interference. From what I can tell, the high beam bulb from Beamtech will not fit into a C5 and be able to close the headlight.
Interference of heatsink and actuator
Old Jan 20, 2020 | 01:38 PM
STRMLNE's Avatar
STRMLNE
There is someone on this forum that has both installed. I just can’t remember who it is.
Old Jan 20, 2020 | 06:25 PM
AUandAG's Avatar
AUandAG
Ah, yes, only one hole for the set screw so I just left the screw out and aligned the heat sink so that it just clears the actuator. The orientation of the heat sink hasn't changed in 20 months.
Old Jan 20, 2020 | 07:20 PM
LstHura's Avatar
LstHura
That certainly is good to know and a little surprising to me. I would have expected normal vibration would allow them to turn. I am waiting to see what Beamtech has to say about this before putting them back in. Besides, it turned cold and will remain so for a few more days. Did you have to adjust the headlight assemblies up or down or was the alignment ok?
Old Jan 20, 2020 | 09:43 PM
AUandAG's Avatar
AUandAG
I only had to adjust the low beams.
Old Jan 22, 2020 | 08:34 AM
LstHura's Avatar
LstHura
I got an email today from Beamtech with the address for returning the bulbs and getting a refund. I am disappointed that they don't fit properly, but more disappointed that they either aren't aware of the problem with the 9005s or are not admitting they know it. I will be paying the shipping cost to return.
To Beamtech Hi beam interference fit
