do you grind 2nd gear
Old Nov 18, 2002 | 08:15 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default do you grind 2nd gear
When you are powershifting, does your 2nd gear grind?
I can powershift 3-4 but 1-2 always grinds .. whats up...
Old Nov 18, 2002 | 10:44 PM
01c5z06's Avatar
01c5z06
Default Re: do you grind 2nd gear (ICULUKN-C5)
Mine is notchy. Sometimes you can feel it not wanting to go in smooth.
Old Nov 18, 2002 | 11:34 PM
scool93535's Avatar
scool93535
Default Re: do you grind 2nd gear (01c5z06)
I replace the ATF with Redline. It has really made a big difference. :cheers:
Old Nov 18, 2002 | 11:38 PM
Joe's Eray's Avatar
Joe's Eray
Default Re: do you grind 2nd gear (scool93535)
I need to do that on mine because mine grinds like crazy going into second. Heck sometimes its even hard to go into first.
Old Nov 19, 2002 | 12:30 AM
rwj383's Avatar
rwj383
Default Re: do you grind 2nd gear (BrightRed C5 SWFL)
those of you with grinding issues, it wont be long before you need a new tranny. I say this from experience. The synchros suckk in these cars. I'm on my 3rd tranny. Well, i thrashed the first one through all the dragracing. The dealer tried to rebuild it under warranty, but the rebuild didnt take because all the shaft bosses in the case were hogged out so the synchros still grinded afterwards. so, they got me a whole new one. you will need a new tranny eventually..
Old Nov 19, 2002 | 12:46 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: do you grind 2nd gear (rwj383)
did you take it in with the bottles? I really dont want to remove mine...
To do you grind 2nd gear
