Rough idle, idle hangs and lean codes.... solved.
Old Jan 28, 2020 | 09:13 PM
gpracer1's Avatar
gpracer1
Default Rough idle, idle hangs and lean codes.... solved.
It’s been a while since I posted, but I finally solved a 6-7 year old problem I have had.
Issue was rough idle (worse when cold and in closed loop) , idle would hang coming to a stop (would stop at under 2 mph on HUD) , crappy low speed low rpm driveability, throwing lean codes all the time P1071 P1074.
Stupid freakin injector orings were hard as a rock at the manifold. Found by spraying propane while watching O2 sensors not switching that were flatlined low, when hit with propane O2 sensor would bump. Also reset the LTFT’s with the Tech2.
$20 in orings and she purrs like a kitten now.
Old Jan 28, 2020 | 11:12 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
Good deal, thanks for posting the fix.
Old Jan 28, 2020 | 11:48 PM
Moved to C5 Tech.
Old Jan 29, 2020 | 08:35 PM
old stingray's Avatar
old stingray
Thanks for the post.
To Rough idle, idle hangs and lean codes.... solved.
