recirc light stays on
Old Jan 31, 2020 | 08:59 PM
66thunder's Avatar
66thunder
2nd Gear
Default recirc light stays on
haven't seen this addressed before. After starting car, recirc light stays on, can't shut off. Same with both buttons. Also have parasitic battery drain, not sure if related. Any ideas or has someone else had this problem?
Old Jan 31, 2020 | 10:16 PM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
There is no feedback from this direction doors so that sort of tells me you've got a problem with the HVAC head unit and you need to either replace that or get it worked on. Or of course work on it yourself. It could be as simple as those resistors that break loose on the boards. I think there are four of them and you could check that. Do a search for dim display fix and you'll find a thread that describes how to fix the HVAC display. It's quite possible the problem is related to your parasitic loss. That's fairly easy to isolate and there are lots of threads on that subject here as well. Lisle tools makes a nice harness that plugs into your meter specifically for checking this. I have one and I think it was around $25. Well worth the savings on aggravation, blowing fuses on your meter trying to jerry-rig the thing with wires and clamps. Btdt.
Old Feb 1, 2020 | 08:48 AM
GUSTO14's Avatar
GUSTO14
66 Thunder, welcome to the Corvette Forum. You've come to the right place to get answers to lots of questions on you Corvette. You may well soon find it the most useful tool in your tool box.
I had a similar problem with my 2000 Hardtop. (I have the manual HVAC controlled system.) The lights in my display would periodically not turn off when the electrical system would go to sleep. As a result it would run the battery down overnight. It took a while to figure it out as it didn't do it every time. I finally spotted it in the garage one night in the dark when I noticed the display was still lit up.
A fully charged battery would normally correct the problem, but since I didn't drive it very much I decided to keep a Battery MINDer on it. I also noticed that whenever the MINDer light was not blinking the display would be lit again. The lights in the display are controlled by a relay. If the relay sticks it can keep power applied even after power to the control circuit (of the relay) is removed.
The HVAC displays are not cheap, but the manual ones are no longer being made, so for the most part you're looking for a functioning used one. Unfortunately age and humidity are the enemy of relay's, so a used one may well be no better than the one you have. The flexible 'skin' of the display also gets very fragile over time, so be sure to get a good picture of it before you purchase. The replacement I bought looked okay, and functions just fine, but the 'skin' is not as nice as my original one.
If anyone knows of a place that refurbishes them, I'd sure like a POC.
A friend tipped me off to Car-Part dot com. It's a great site for a myriad of obsolete parts and you can find most anything on it. They also typically have good pictures of the components and everyone I asked questions of, answered back promptly. One vendor mentioned he was expecting a few in from a repair facility near Jacksonville, Florida, but when I asked him who they were he avoided answering me.
Good luck... GUSTO
Old Feb 1, 2020 | 11:35 AM
GCG's Avatar
GCG
Originally Posted by GUSTO14
...The replacement I bought looked okay, and functions just fine, but the 'skin' is not as nice as my original one...
GUSTO, why don't you try to swap "skins" between them?
Old Feb 1, 2020 | 02:45 PM
GUSTO14's Avatar
GUSTO14
I've looked it over closely and didn't see an easy way to remove it without damaging it. Have you removed the skin on one of these? Any suggestions?
The replacement control display is not that bad, and I was hoping to get the original repaired and reinstall it without risking damaging it.
Thanks, GUSTO
To recirc light stays on
