Z06 tires
Old Feb 5, 2020 | 01:17 PM
mcm95403's Avatar
mcm95403
Default Z06 tires
Hi Guys,
I'm looking at getting a 2004 Z06 but it seems tire selection is REALLY limited. What are you guys doing for tires?
Thanks!
Old Feb 5, 2020 | 06:48 PM
byte_me's Avatar
byte_me
Originally Posted by mcm95403
Hi Guys,
Thanks!
The 17’s in stock sizes are basically non-existent. I went to 4 18’s with stock Z wheels and love it. A lot of guys running this setup.
I even have 295/35/18’s on all 4 corners of my 04 Z with zero issues. You can buy a set of new Speedlines from House of Wheels and run a staggered set of 275/35-295/35 F/R. I did this in my previous 01 Z.
Old Feb 5, 2020 | 07:50 PM
493lszosix's Avatar
493lszosix
275/40/17 front 305/35/18 rear
Old Feb 6, 2020 | 12:28 PM
Speedy007's Avatar
Speedy007
Define limited there’s all sorts of tires available in stock sizes and they are not really expensive until you start look at sport cup 2’s even then 300 a tire isn’t all that bad!
255/35/19 x 285/30/20
Old Mar 4, 2020 | 03:43 PM
Notover's Avatar
Notover
I'm running stock Z06 wheels on an 03 coupe. Is there any difference in the wheel well clearance in the front or rear? I'd like to get a tire with a slightly taller sidewall for a better ride. I don't track the car so performance is not a real issue. Any suggestions?
Old Mar 4, 2020 | 04:02 PM
Speedy007's Avatar
Speedy007
I ran 40’s up front on 17’s I wouldn’t see why a 265/ 45 the front wouldn’t clear if the car isn’t dropped in the front ! Good luck even with my 19 in the front I could prob clear a 40 & the the car is lowered !
Old Mar 4, 2020 | 05:22 PM
Notover's Avatar
Notover
Thanks! I may give those a shot.
Old Mar 5, 2020 | 01:14 PM
pantspuppet's Avatar
pantspuppet
6th Gear
I got some Continental Extreme Contact Sports in 275/40ZR-17 & 295/35ZR-18 sizes last August. I'm really happy with them. I like to drive pretty hard in the mountains and they have great grip...even in light rain. I haven't had them long so I can't comment on treadwear. They were the only option I could find in performance/summer tires for the stock Z wheels.
Old Mar 5, 2020 | 08:11 PM
Under50's Avatar
Under50
went through the same issue as you did OP about a week ago..either you spend $1500ish on summer tires on stock sizes or what i did i went 255/40/17 up front and kept stock 295/35/18 and get the Continental extreme contact DWS at 880ish i have about 100miles on the tires and like them so far
To Z06 tires
