Fuel rail fitting?
Old Feb 6, 2020 | 02:34 PM
04zjimc's Avatar
04zjimc
Default Fuel rail fitting?
So the fuel rail is -4an, can I run a -4an female braided line to the rail? then to my fuel sender? That would eliminate the fitting for the rail..? Thanks
Old Feb 6, 2020 | 04:25 PM
StingrayRebel's Avatar
StingrayRebel
what are you trying to accomplish?
Old Feb 6, 2020 | 04:33 PM
04zjimc's Avatar
04zjimc
I'm hooking up a eletric fuel pressure gauge and I have a -4an line cant I just screw that to the rail?
Old Feb 6, 2020 | 04:50 PM
mykream's Avatar
mykream
Yes, remove the shrader valve at the end and thread your 4an hose nut to it.
Old Feb 6, 2020 | 04:55 PM
04zjimc's Avatar
04zjimc
ok good! Should I use some teflon tape? Thanks
Old Feb 6, 2020 | 04:57 PM
mykream's Avatar
mykream
No.. You don't use anything with AN fittings
Old Feb 6, 2020 | 06:49 PM
04zjimc's Avatar
04zjimc
ok thanks!
Old Feb 6, 2020 | 07:02 PM
StingrayRebel
yeah you can put it on the end of the rail or most aftermarket fuel pressure regulators have a 1/8 npt port for a pressure sender if you happen to have one of those... if you put it on the end of the rail make sure the female threads for the sender side are correct, most of them are npt and not -an
Old Feb 7, 2020 | 10:56 AM
Moved to C5 Tech.
To Fuel rail fitting?
