Plugs & Wires Recommendations
Old Nov 19, 2002 | 05:21 PM
1 BAD C5's Avatar
1 BAD C5
Default Plugs & Wires Recommendations
Has anyone had good success with Beru Silverstone spark plugs? They claim to be better than platinum and other competive plugs. Any comments or suggestions? I am also looking at a set of plug wires (Nology Hotwires) these are be far more expensive than others that I have seen such as MSD. Is there really going to be that much of a noticeable difference for a 200.00 difference between wires?
Old Nov 19, 2002 | 05:50 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Plugs & Wires Recommendations (1 BAD C5)
capacitive ignition is snake oil.
For a more indepth understanding of plug wire technology, I recommend reading: http://www.magnecor.com/magnecor1/truth.htm
Old Nov 19, 2002 | 09:47 PM
MYFRSTC5's Avatar
MYFRSTC5
Save your money. I believe the consensus on this forum is that copper is the plug of choice for performance not for durability. If you don't mind changing the plugs every 15K-20K miles then go with a set of NGK TR55's and a set of MSD Wires. The wires will run you about $80 and the plugs aree less than $20. :cheers:
Old Nov 19, 2002 | 10:31 PM
Chris@SD's Avatar
Chris@SD
Big waste of money. Go with either the Taylor wires or the MSD wires as well as a set of NGK TR55 plugs. Saves money and performs better. :cheers:
Old Nov 20, 2002 | 08:37 AM
TriBlakC5's Avatar
TriBlakC5
Taylor wires (don't forget the boots) and Bosch +4 plugs. Works good for me.
:cheers: :chevy
Old Nov 20, 2002 | 12:51 PM
TexasVetteMan's Avatar
TexasVetteMan
Default Re: Plugs & Wires Recommendations (TriBlakC5)
i recently replaced my stock plugs and wires w/ taylor wires & NGK55 plugs.
Work great! Very reasonable also. What is the deal about the boots. Will that help w/whining noise an am radio after the wire change. Or is it just a heat shield for the wires. :chevy
Old Nov 20, 2002 | 01:41 PM
ModifiedC5's Avatar
ModifiedC5
I went with the NGK Iridium plugs (TR55IX). They are supposed to require less energy and provide better spark. check out http://www.ngk.com
To Plugs & Wires Recommendations
