Passenger Window Problem
Old Feb 8, 2020 | 02:59 PM
VZVette's Avatar
VZVette
Default Passenger Window Problem
The passenger window on my C5 convertible will only go up a few inches. It will go all the way down, but only raises slightly. Any assistance will be greatly appreciated. Thanks in advance for your help.
Old Feb 9, 2020 | 01:29 PM
UM Rebel's Avatar
UM Rebel
Does it make a grinding sound when you try to raise it?
Old Feb 9, 2020 | 02:11 PM
VZVette's Avatar
VZVette
No, it doesn’t make a grinding sound. It just goes up a few inches and the stops. Thanks
Old Feb 9, 2020 | 05:55 PM
UM Rebel's Avatar
UM Rebel
You probably need a new regulator. I installed both sides a couple of years ago. Bought them off eBay.
https://www.ebay.com/itm/97-04-Chevy...rd!70508!US!-1
They work great. Easy to install. Watch the video
Good luck
Old Feb 9, 2020 | 09:15 PM
VZVette's Avatar
VZVette
Thank you for your help and the eBay link and installation video.
Old Feb 10, 2020 | 07:15 PM
Joewass65's Avatar
Joewass65
If it’s not making a crunching noise I would try the punch method. Hold the window button up or down and punch the door panel right next to the handle. (Sounds crazy but do a search. Works most of the time)
Old Feb 10, 2020 | 07:33 PM
VZVette's Avatar
VZVette
Thanks for the suggestion. I did try the punch method; however it will go back down but still only rises up a few inches. I ordered a regulator with motor from eBay and should have it by Friday.
Old Feb 10, 2020 | 07:52 PM
Joewass65's Avatar
Joewass65
Be careful prying the pins when taking the door panel off. The plastic retainers on the door panel are very brittle.
Old Feb 11, 2020 | 07:20 AM
VZVette's Avatar
VZVette
Thanks for the heads up.
To Passenger Window Problem
