Cruise control issue
Old Feb 15, 2020 | 09:27 AM
Mike-R's Avatar
Mike-R
Default Cruise control issue
Before I claim my cruise control on my C5 isn’t working...how exactly do you activate it? Done some googling but it more relates to it being broken, rather than turning it on. Is it just a case of finding your speed and then flicking the switch over to the ON position, or does another button need to be pressed somewhere else? All cruise I’ve had before needs to be turned on and then set.
Anyway, if that is the method then it’s definitely not working. I’ve read a bit about hooking your foot behind the brake pedal (it’s an auto) so I’ll be trying that, and if there’s any guides to adjust the brake switch that’d be helpful. Failing that are there any other common reasons for these to go? Big cruise control fan so I’d like it sorted.
Old Feb 15, 2020 | 09:55 AM
rrwirsi's Avatar
rrwirsi
Here are the Cruse Instructions from my '04 manual:1. Move the cruise control switch to ON.
2. Get up to the speed you want.
3. Press the SET button at the end of the lever and
release it. The cruise set speed will be displayed
by the Driver Information Center (DIC).
4. Take your foot off the accelerator pedal. The pedal
will return to an idle position.
Old Feb 15, 2020 | 10:56 AM
feeder82's Avatar
feeder82
If you look at the turn signal lever the cruise switch has 3 positions OFF, ON, R/A it has it be in the ON position to activate. To set it at speed you push the button on the end of the lever. To speed up when its set you can push the switch over to the R/A position, which stands for resume/accelerate. To slow the set speed push the button on the end of the lever.
Old Feb 15, 2020 | 01:12 PM
Mike-R's Avatar
Mike-R
Oh doy, didn’t see the button on the end of the stalk, will try this next time I’m in the car and hopefully it’s working! Thanks all.
To Cruise control issue
