Door Lock
Old Feb 24, 2020 | 01:51 PM
RPGR90s's Avatar
RPGR90s
Default Door Lock
Took my C5 Vert out of storage yesterday and noticed that the driver's door doesn't unlock with either the remote, or via the Door Lock button once inside. The remote will lock the door as well as the Lock button once inside.
I'm guessing this might be a problem with the LDCM (Left Door Control Module). I didn't see any codes while scanning through the DIC list.
Thanks,
RPGR90s
Old Feb 24, 2020 | 01:54 PM
v6turbo87's Avatar
v6turbo87
Thanks,
RPGR90s
Most likely the unlock relay has gone bad in the module. A bad relay will not set a code.
Old Feb 26, 2020 | 09:34 AM
RPGR90s's Avatar
RPGR90s
Default Door Locks
Thank you very much. I'll pull the panel this weekend and see about replacing the relay.
RPGR90s
To Door Lock
