2001 C5 operating temperature
Old Mar 1, 2020 | 07:45 AM
Clayton59's Avatar
Clayton59
Default 2001 C5 operating temperature
Good morning Forum. My C5 normal operating temp was basically between 196 and 201. I think this is within the so called "Sweet Spot". My water pump started leaking a few weeks ago and my temperature started fluctuating more than what I would call normal. So I had it changed. At the same time, I had them change the thermostat (came with the water pump). Now it seem the normal operating temperature is between 172-178.
1) Is this ok, or should I have them replace the thermostat again?
2) Is there now a possible issue with the temperature sensor?
3) Possibility of just the wrong thermostat?
4) what will it hurt to leave it run at the cooler temperature?
Old Mar 1, 2020 | 11:51 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
what stat did they install ??? 160 I presume !!! I am a the very few here rather to have my engine run cool (heat kills everything on a car) I run a 180 stat and mine runs in the 190 range, I think that's perfect !!!
Old Mar 1, 2020 | 10:57 PM
foggy's Avatar
foggy
Yup, It sounds like they installed a lower temp TStat..
If your car is only running in the 170's... That's too low.. Not good for engine longevity.
The LS motors like to run a little warm.. its better for ring seal, wear, etc
The 190's to me is the sweet spot.
I run a 180 TStat, so it usually runs about 190. My fans are tuned to turn on at 202 low speed and 212 high speed
Old Mar 1, 2020 | 11:14 PM
C6Z_LS7's Avatar
C6Z_LS7
OP sounds like it’s running fine and you’re not running the car long enough to see temps above 178+
A thermostat does not run the engine at lower temps. The thermostat opens at the temp listed to allow coolant to flow into the block. either at 160, 170, or 180. Unless you live in Siberia, I would first start by running the engine longer to get above 178 if that’s your concern. But most likely the lower temps you are seeing are due to a properly working water pump and new coolant. Lower degree thermostat does not have any ill effects.
Old Mar 2, 2020 | 06:55 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
A thermostat does not run the engine at lower temps. yes it does !!! The thermostat opens at the temp listed to allow coolant to flow into the block. wrong the coolant circulates in the block until the stat slowly opens allowing coolant to start flowing to the radiator either at 160, 170, or 180. Unless you live in Siberia, I would first start by running the engine longer to get above 178 if that’s your concern. But most likely the lower temps you are seeing are due to a properly working water pump and new coolant. Lower degree thermostat does not have any ill effects.
what does a thermostat do ??? it controls temp. whether in in your house or in your engine !!! our C 6 Z06 has a 170 stat and runs about 180, our three C 5's have 180 stats and run about 190 !!! if the stats don't run at different temps then why do they make different temp stats ????
Old Mar 2, 2020 | 10:13 PM
C6Z_LS7's Avatar
C6Z_LS7
wow relax... why are you yelling? Operating temperatures are not controlled by the thermostat, its all on the cooling capacity and flow through the radiator and block. Yes, you're right...coolant does circulates through the block. I should have been more clear, once the stat opens it allows the coolant flow through the entire cooling system. The lower thermostat just opens up earlier but the operating temperature will have the same result unless other changes are made. Sounds like the cooling system is doing its job. On a stock tune, engine, radiator... to help answer the OPs question/concern, no ill effects. Unless you live in severe cold weather, it might take longer to warm up the car.
Clayton59, do you know what thermostat came with the water pump?
Old Mar 3, 2020 | 12:11 AM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Respectfully disagree. My car and ones before run like a champ in the 170s. Mine is tuned for its 160 stat.
With my 160 stat oil temp can be 205 and up to 240 running wide open in the hills. I’m glad the stat isn’t staying closed until factory 195.
Old Mar 3, 2020 | 08:34 AM
VFR RC46's Avatar
VFR RC46
I would say, as long as you get your oil above 180*F before beating on it, above 212*F for at least 30 mins once a week ( to burn off condensation) and don't get the oil above 240*F (maybe 250 at most? I think the oil start breaking down around 275?), you are in good shape...
Coolant temp is less important than oil temp, as long as you don't overheat and stay near the normal range.... I believe, like other have said, the power sweet spot is around 180*F.
Old Mar 3, 2020 | 10:26 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
you know little about the cooling system and ever less about the internet, THIS IS YELLING !!!!!!!
Old Mar 3, 2020 | 10:32 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
the engine temp will generally run about 10 degrees above set stat, the stat does not open all at once but will slowly open and close on temp, a 180 stat will get the engine to that temp then slowly open to the rad bring the rad temp eventually to 190, as the the ambient air (less than 100 degrees normally) goes though the rad it cools the coolant back down to the stat temp, because the stat dictates it !!!!!!!! I am amazed how few get this ???? yes it will run hotter than the 10 over from time to time but can eventually get back down to stat temp. for example our C6 Z06 (600 to the rear) with a 170 stat will go as high as 217 (the highest we have seen) during 16 AutoX runs, then on the way home will cool back to 185 or so !!!
Old Mar 3, 2020 | 04:17 PM
C6Z_LS7's Avatar
C6Z_LS7
Just because you're yelling doesn't prove your points. And nobody cares about how many C5s and C6s you have and what's perfect you. You contradict yourself on operating temps and stats. Clearly I'm not the one who knows nothing about cooling systems. You're hijacking this thread and making it about you. Answer the OP, there is no ill effects running a slightly lower degree stat
Old Mar 3, 2020 | 04:49 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
I did answer the op, the first post ???? you can't read either !!!!!!
Old Mar 3, 2020 | 05:37 PM
C6Z_LS7's Avatar
C6Z_LS7
Originally Posted by Pounder
I did answer the op, the first post ???? you can't read ether !!!!!!
Ya I must have missed that from all the yelling. And you can't spell. So I guess we both failed English.
Old Mar 3, 2020 | 06:32 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
so I missed the i and there was no yelling !!!!
Old Apr 8, 2020 | 06:48 PM
Clayton59's Avatar
Clayton59
Didn't mean to start an argument... I'm not seeing anything puzzling... I'm gonna keep it as it is for now.
May change it come Fall though... We'll see.
Thanks guys...
Old Apr 9, 2020 | 11:33 AM
My Vette Life's Avatar
My Vette Life
Just leave everything to stock specs and you'll be more than good!
The moment you start modding well all kinds of different answers you will get.
Safe route is stock
Old Apr 9, 2020 | 11:53 AM
slothman's Avatar
slothman
imo, in hot *** weather a colder Tstat is a good idea.
To 2001 C5 operating temperature
Old Apr 10, 2020 | 10:21 PM
Supercharged111's Avatar
Supercharged111
The trick to longevity is for oil to be in the 200-220 range. If you run a 160 stat and don't rip on the car, the oil will never hit 200+ and will cause more wear. What that truly means is anyone's guess. Maybe your motor lasts 300k instead of 400k?
Old Apr 11, 2020 | 12:05 AM
lionelhutz's Avatar
lionelhutz
This is simply wrong. No if's and's or but's. Wrong.
The thermostat begins opening at it's rated temperature and then opens fully from there as the coolant temperature increases another 10* to 20*. The thermostat isn't just open or closed.
Given enough radiator and fan, the engine will ALWAYS run just above the thermostat rated temperature. The thermostat will partially open and regulate the radiator flow to maintain the coolant temperature. My C5 with the stock 193* thermostat runs just a little over 193* at the highway speeds I normally drive until I slow way down or stop and there is no longer enough airflow. At that point, the coolant rises until the fans come on and once again provide enough airflow. My 65 Impala with electric fans does the same thing.
The fact the OP's car is running at a lower temperature after the thermostat was changed to a lower temperature rated thermostat also proves the thermostat regulates the lower end of the coolant temperature.
There wouldn't be thermostats with different temperature ratings sold if they didn't change the operating temperature of the engine.
Old Apr 11, 2020 | 12:13 AM
lionelhutz's Avatar
lionelhutz
Any insight into why the oil being that hot helps with engine longevity? What exactly does it protect that say 195* oil can't protect?
The OLM counts 50*C oil the same as 100*C oil, so GM doesn't seem to believe the oil needs to get that hot to have a full life.
My C5 on the 25 minute drive to work barely gets the oil to 190*F. Sometimes it's even cooler when I park it. On much longer highway drives the oil temperature typically won't go above 200*F either. And that's with the stock thermostat.
