Question about testing window tip-in
The signs of too little tip-in are well documented here. I have read a slew of CF threads have complaints about leaky windows (air and water) and responses that provide directions on adjusting tip-in. In addition to these directions, I have the FSM...so how to make the tip-in adjustment is not my issue.
I just replaced the roof gutters on my '02 Z06. Despite my best efforts to reposition everything as removed, I'm sure there are slight tolerance differences now since new parts have been installed, new sealant, new foam, etc. The old installation was beaten up and had been patched up at least once.
The tip-in now seems a wee bit too much (would like to test it, if possible, before making any adjustments), and the window heights could drop about 1 - 2 millimeters
I just completed driver window adjustments this morning. I reduced the closing height by two screw turns (CW, lower the closing height) and adjusted the tip-in by two screw turns (CW, move top of window outward). I did the paper test (used a dollar bill) and had snug and even tension all around. The passenger side window was perfect, so I used it as the benchmark for how I wanted to adjust the driver's door. Both windows are now perfect in terms of alignment and closing height.
M.Y., do you recall in which section is the window adjustment in the FSM? Or what term should I look up in the index. I think I need to do this. After finishing the molding replacement the door is way too hard to close.
