Electrical
Old Mar 5, 2020 | 07:28 AM
97Chuck69's Avatar
97Chuck69
Default Electrical
Got a 97 C5. My switch on the dash will not open the rear hatch and my fog lights will not come on. I have power to the switch but nothing works. I am thinking switch. Have checked the fuses and all are good. ALSO my switch to release my gas door will not work either. I have checked fuses and all are good but yet no power to the end of the plug. ALSO my right turn signal will not blink inside the dash but it does work outside. HELP
Old Mar 5, 2020 | 07:38 AM
pauly1119's Avatar
pauly1119
St. Jude Donor '06-'11
I would start by checking the battery voltage, could just be a battery. They do weird things when the volts drop, could also be a computer. I had a 1998 that had a small battery leak years ago that damaged the BCM and had some of the same issues your having now. Also check the grounds and cables.
Old Mar 5, 2020 | 10:41 AM
97Chuck69's Avatar
97Chuck69
Thanks for the quick come back but I will say that when car is not in use it is always on a maintainer charger, and I have also gone through all the grounds. I will say that I have had the gage cluster out a number of times and always when I put it back everything worked accept this last time. As I said I do have power to the plug but when I plug it into the switch nothing works, I am thing the switch is bad but really do not have a way to check it out.
Old Mar 5, 2020 | 11:39 AM
jcgunn's Avatar
jcgunn
The lights have to be in parking or headlight for the fog lights to come on. The parking brake has to be engaged for the hatch to open.
Old Mar 5, 2020 | 11:43 AM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
It does sound like a switch issue off hand. If you happen to know anyone with a C5 maybe ask if you can borrow the hatch switch for a couple minutes. Can you check the switch while you have it out and see if it has an open and closed signal? I've never tried that on that switch yet so not sure how it operates.
Old Mar 5, 2020 | 03:03 PM
97Chuck69's Avatar
97Chuck69
I have tried to check for continuity in the switch and it is blank
Old Mar 5, 2020 | 05:41 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
I have never used my parking brake (I live in Fla and
no hills) and my hatch always opens.
OP have the battery tested at a parts store
its free..............
Old Mar 5, 2020 | 05:45 PM
1997 C5's Avatar
1997 C5
I have 97 C5, my fog lamp will not come on. The fog lamp switch is light when on but fog lamp will not come on. Where is the fog lamp fuses so I can check it over the weekend.
Thanks in advance
Old Mar 5, 2020 | 07:34 PM
pauly1119's Avatar
pauly1119
just seems like too many things not working to be the switch but you never know, did you check the volts at the battery? when the car is running? under load with a few things on? I have had a battery with 11.9 volts and it was toast.
Old Mar 6, 2020 | 07:35 AM
97Chuck69's Avatar
97Chuck69
Under the hood fuse box #6 i believe
Old Mar 6, 2020 | 07:43 AM
Race Prepared's Avatar
Race Prepared
With so many systems affected, might be a ground. Also, have you checked to see if codes are present?
Old Mar 6, 2020 | 08:05 AM
97Chuck69's Avatar
97Chuck69
Not yet but that is next
Old Mar 6, 2020 | 11:08 AM
Moved to C5 Tech.
Old Mar 6, 2020 | 11:34 AM
jcgunn's Avatar
jcgunn
I stand corrected. I just checked. On the A4 Vert the transmission must be in P for the hatch to open. The parking brake does not matter.
Old Mar 7, 2020 | 10:36 AM
97Chuck69's Avatar
97Chuck69
Default Electicial
On my hatch not opening with the switch does anyone know if there is a emergency release like on the fuel door. Even if it is a jumper wire in the plug and what prongs would you use.
To Electrical
